Not sure if this is helpful but the plastic from a 1-gallon used bottle of antifreeze or oil is fairly rigid... The color scheme might not match thou, but the semi-curve of a cut-out just might be the perfect fit for some application.
If not for the vehicle, I usually cut one open if I need a flat pan with edges for use as a 'parts' tray
