DIY Shaved/Interior Antenna - Fuelly Forums
Old 02-12-2009, 07:40 AM   #1
aalb1's Avatar
For all of you familiar with Honda Civic Antenna's many Civic owners refer to them as R/C Antenna's because of their location
Well I went through a car wash and forgot to put my antenna down. The car wash attendant didn't even bother reminding me either. My bad and his bad.
On the way down the highway it was flapping in wind and hitting the roof of my car. When I got out I noticed it was hanging by a thread of metal and when I bent it back into place it snapped off immediately.
I thought this was a chance for me to shave my antenna but looking at internal antenna prices I didn't feel like paying $40+ for one. So I went to AutoZone and took a chance with a $9.99 3-Mast Universal Antenna. I ran it along the passenger side pillar, gently bent it 90* to run at the top of the window, then bent it 90* downward behind the Rear View Mirror. I also grounded it with a self tapping screw to the body.
Here are the results:
"First Part of Mast bent 90*"
"Antenna wire and base tucked behind the pillar. Base grounded and antenna mast wrapped in electrical tape since it shouldn't see ground."
"Antenna bent 90* and secured to the rear view mirror bracket"
"Bottom of the antenna"
"The circled area is all that I am able to see while sitting in the driver's seat"
"No More Antenna! The hole is filled with caulk but the whole cap will be replaced with a flat OEM Antenna-less roof cap."
Old 03-02-2009, 07:20 PM   #2
winkosmosis's Avatar
Good work. How is the signal? I need to do this with my Miata since the power antenna doesn't work-- but I'll run it along the passenger seat probably. I will just use a wire though.
winkosmosis is offline   Reply With Quote
Old 03-02-2009, 08:46 PM   #3
aalb1's Avatar
Believe it or not I haven't noticed a difference in reception. I only listen to two public radio stations in the area so I don't know how good of a judgment I can give.
When you do, do this make sure the antenna is grounded or else you will get a lot of static.
Old 03-16-2009, 11:40 AM   #4
Notice any fuel economy impact?
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 12:20 PM   #5
aalb1's Avatar
All I got is the power of positive thinking at this point but every little bit helps.
Old 03-16-2009, 01:14 PM   #6
GasSavers_BEEF's Avatar
what about legal.
I bet the state inspection station is going to have a hay day with you on that setup.
Old 03-16-2009, 01:27 PM   #7
aalb1's Avatar
what about legal.
How so? I can't think at all in my mind how this would not pass inspection... more so why the inspector even care?
Old 03-16-2009, 01:51 PM   #8
That's true enough. Hikers cut off tags from clothing and shorten toothbrush handles!
co de pen den cy
Function: noun
Date: 1979
Old 03-16-2009, 04:41 PM   #9
aalb1's Avatar
Never heard that saying but I think I understand it.
Old 03-16-2009, 06:19 PM   #10
It's not a saying, they actually do stuff like that to trim all the weight they can. Hardcore.
co de pen den cy
Function: noun
Date: 1979
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 11:17 PM
Sterling Heat pump Steve6f8eh Experiments, Modifications and DIY 4 07-29-2008 01:42 PM
Traffic Jam = P&G opportunity = FE++ DracoFelis General Fuel Topics 12 05-14-2008 02:44 PM
Anybody know where to get an ipod drive lovemysan General Discussion (Off-Topic) 1 06-13-2007 09:08 PM
Compression Tester krousdb General Maintenance and Repair 7 07-12-2006 02:59 PM
