Difference between Cd and Cda? - Fuelly Forums
Old 07-19-2008, 08:20 PM   #1
Hasbro's Avatar
Does Cd consider more factors? My 04 Civic Si has a Cda of .33 but would Cd be different and why?
Hasbro is offline   Reply With Quote
Old 07-20-2008, 02:40 AM   #2
CdA actually considers more factors, as it is Cd (drag coefficient) multiplied by A (the frontal area of the object in question). The value you found has to be Cd...it's far too small to be the CdA value of a vehicle that size unless it has a Cd value of <0.15 (which it doesn't )
For example: Car A has great aerodynamics (Cd=0.25), but a very tall roofline and, consequentially, a large frontal area of 3.0m^2. Car B is less slippery (Cd=0.35), but is smaller overall and has a frontal area of only 2.0m^2. At any speed, Car B will cause less aerodynamic drag and waste less energy overcoming it.
Just in case you're interested, the formula for aerodynamic drag is:
1/2 * rho * velocity^2 * Cd * A where rho is air density (which changes with temperature, altitude, etc)
SteveX82 is offline   Reply With Quote
Old 07-20-2008, 08:04 AM   #3
thornburg's Avatar
Originally Posted by SteveX82 View Post
1/2 * rho * velocity^3 * Cd * A where rho is air density (which changes with temperature, altitude, etc)
I thought it was v^2, not v^3 ?
Old 07-20-2008, 08:38 AM   #4
You're right....I was thinking of the power consumed by the aero drag. The appropriate change has been made! Thanks for noticing
Old 07-21-2008, 06:58 AM   #5
Think of CdA as Cd times A. It's a coefficient times an area. If the car were doubled in size the coefficient would not change, but the area would.
A jet aircraft has a lower Cd than a motorcycle, but the much smaller area of the bike gives it lower total air drag or CdA.
GreenSwitch GasSavers_DaX General Discussion (Off-Topic) 10 11-30-2007 11:13 AM
Woo! Tripminder! Any 80's ford EFI, take a look. Wyldesoul General Fuel Topics 6 06-17-2007 06:43 PM
