Completed Wheel Well Covers - Fuelly Forums
Old 10-16-2007, 03:00 PM   #1
I hate calling them "skirts", especially on an F150 - so they are covers. This construction method would work for any car though.
Made an aluminum frame out of 8' aluminum angle pieces by cutting triangles out of one edge. This allowed for it to mold to the inside of the wheel well lip and still give me a surface to attach the cover to. I did drill and screw this aluminum piece to the well lip. Next the cross braces were bent so that they would clear the tire, and were then riveted to the half-circle. A little brace piece was added for the bottom bracket - I wanted more than 2 rivets holding that on!
Next I used metroMPGs newspaper method to get an outline of my wheel well, transposed that to a piece of choroplast. Cut the choroplast, taped it in place on the wells, drilled holes for plastic rivet/screws that would hold it onto the frame. Drilled the frame holes while the paint was drying on the choroplast (4 coats - we will see how long it lasts... at least its an easy quick spray paint touch up to scratches that may occur). I put door edge around the edge of the choroplast to give it a finished look and then attached it to the framework.
I designed it this way so that I can remove it easily in 2 steps...cover first then the aluminum frame... when I need to have tires replaced. If I have a flat, the lug-nuts are all accessible when I lift the truck. Not sure if there is clearance to get a tire swapped without removing it, but hopefully Ill never find out. (of course now that I say that, Ill have a flat tomorrow).
I have another 800 mile round trip run next week - will see what kind of difference these things make - hopefully a pretty good one - those wells are huge back there.
Take care.
-Jeff
jeffreymccoy is offline   Reply With Quote
Old 10-16-2007, 03:06 PM   #2
Looks nice, too bad the skirts hardly cover your tire,
Old 10-16-2007, 03:08 PM   #3
UfoTofU's Avatar
Those are wicked clean.
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 10-16-2007, 03:12 PM   #4
cfg83's Avatar
jeffreymccoy -
I've never seen the "cut triangles" into the aluminum angle pieces before.
Man is that a clean mod. You'll be starting a new fashion trend in no time!
Old 10-16-2007, 03:17 PM   #5
eh - I know I know, but it is a truck, and Im going for something similar to this when Im done.
http://www.evworld.com/article.cfm?storyid=870
I got 23.1 hwy tank before this change...Im really hoping to see 24-24.5 with it. Will find out next monday/tuesday. The hard part for me is not making some other change before the trip, so I know what each change does. Then again - I may get ambitious...who cares what changes makes the most impact - they all work together to give the biggest bang.
Thanks for the feedback.
Old 10-16-2007, 03:38 PM   #6
GasSavers_Red's Avatar
Very nice
Old 10-16-2007, 03:52 PM   #7
isn't most of drag(in that area) from the wheel wells, not the wheels/tires themselves? not criticizing your post, just really interested.
Old 10-16-2007, 04:13 PM   #8
Well, I'm not so sure, but I think a lot of it has to do with the wheels, particularly how much air they suck in and all that. I know for bikes the inside of the wheels pose lots of drag, but of course that's different, I was just excited to learn it.
Another source of drag is just plain old how far the wheels stick out under the vehicle. I'm not the best person to really answer the question though.
Old 10-16-2007, 04:54 PM   #9
lovemysan's Avatar
Another user joins the wheel skirt group. Love it. The only problem I can see for you is this. When you tell certain people that you get 24hwy they'll say stuff like "I have a v6 dodge ram and I get 30mpg all the time". But of course that really isn't a problem is it.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 10-16-2007, 05:21 PM   #10
Nice work.
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 01:25 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-22-2008 12:25 AM
Tailgate jcknight007 Experiments, Modifications and DIY 5 06-05-2007 09:48 PM
So how much advanced timing is to much? kickflipjr General Fuel Topics 17 12-22-2006 10:29 PM
Why don't we have small Isuzu diesel pickups? Why!!?? omgwtfbyobbq Diesels 35 11-29-2006 10:00 PM
