I plan to do a full cover using 4 low-clearance conveyer rollers (1/2" x 6") spaced so they only contact the edge of the tire and push the cover outward during low speed turns. It will remain closed during high speed lane changes, etc. It will be hinged at the top with a piano hinge and with springs at the bottom to hold it shut when the tires aren't pushing it open. I hope to fabricate it from a steel sheet, but if my metal skills aren't up to the challenge, I'll make the cover from a framework of aluminum bar stock covered with coroplast.
