Civic hatchback aerodynamics - Page 4 - Fuelly Forums
Old 04-24-2006, 07:10 PM   #31
perfect conditions. that's
perfect conditions. that's awesome.
i love reading these posts. they inspire me to continue chipping away at my car's aero issues.
i pulled a hubcap off the car tonight and brought it inside to mull over how best to streamline it (cover it fully or just cover the holes). and i worked on my permanent set of side skirts this afternoon as well.
what's up with photobucket? how come your pics disappeared?
Old 04-24-2006, 10:51 PM   #32
Send a message via AIM to molecule
maybe thats why we are
maybe thats why we are burning a hole in the ozone layer
warming up earth permanantly to save fuel
its all intentional...of course...
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 04-25-2006, 12:51 AM   #33
krousdb's Avatar
No time to work on my wheel
No time to work on my wheel skirts. Im swamped at work! WHo knows when I will get that done.
Old 04-25-2006, 08:38 AM   #34
basjoos's Avatar
I don't know why the photos
I don't know why the photos stopped appearing, but I'll post then again below.
aerocivic.com
Old 04-25-2006, 09:04 AM   #35
basjoos's Avatar
The aero mods resulted in no
The aero mods resulted in no noticable change at low speeds (below 35mph), but significant changes above 60mph. The increase in drag that I normally start to notice as I get above 65mph is greatly reduced and when I let out the clutch and coast, the speed takes much longer to come down than it used to. The decrease in drag has given me the effect of a horsepower boost at highway speeds and I can now pull hills in 5th at 65mph that I used to have to shift down to 4th to maintain speed on. Wind noise is greatly reduced and road noise is somewhat reduced. All in all, it was a great return on about $50 in parts and most of a day's worth of work on the car. It resulted in an mpg boost at interstate speeds from 44mpg to 62mpg and the mpg's for local driving went from the 54mpg typical for this time of year up into the upper 60's (hopefully into the 70's with some more tweaking and warmer weather). If the car companies were serious about improving mileage, you think they could do this treatment to the new cars they sell.
aerocivic.com
Old 04-25-2006, 10:23 AM   #36
tomauto's Avatar
Send a message via AIM to tomauto Send a message via MSN to tomauto Send a message via Yahoo to tomauto
i can't wait
I just can't wait to start my own undertray. This seems like almost an obvious thing to do to vehicles. The general public just doesn't realize that it can hurt economy of a vehicle. Maybe it is because they can't see it normally.
How many mounting points did you have on the undertray?
Current Stable
tomauto is offline   Reply With Quote
Old 04-25-2006, 11:01 AM   #37
basjoos's Avatar
On the Civic hatch, the
On the Civic hatch, the exhaust runs down the center tunnel and then cuts over to the right side of the car by the rear wheel. I ran Coroplast down the left side from under the front bumper to the rear of the car, spanning from the the plastic curb at the side of the vehicle (where the lift points are) to the frame at the edge of the center tunnel. On the right side, the Coroplast ran from under the front bumper to just ahead of where the exhaust pipe curves to the right side of the vehicle. Then I spanned the tunnel with roof flashing. I drilled and tapped for 8-32 screws (used screw and fender washer) about every 14" or wherever I could find a suitable attachment point if the frame wasn't available over the the entire span. I ran white duct tape over the seams and screw heads and ran metal foil tape over the seams by the roof flashing. The hardest part was bridging the area under the gas tank, since I obviously couldn't drill into any of the metal there and the exhaust ran through the linkages of the right rear wheel which limited where I could use Coroplast over there. In the engine compartment there is a fairly large opening on either side opening into the front wheel well where the drive shafts attach to the front wheels, so I used these for the radiator air exhausts. Since I took these pics, I've had to open up the grill block some more, so I now have a single center 4" x 4" opening and the smaller opening on the right side. The taped-over opening is for the AC radiator and I'll open it if I need it when it gets hot enough to require use of the AC. Once I determine how much radiator opening I need, I'll replace this grill block with one that I can manually adjust the openings of from inside the car. Look at Krousdb's undertray installation on the Del Sol Aerodynamics thread for additional pointers as I used his installation as a referance when installing my own underbody panels.
aerocivic.com
Old 04-25-2006, 04:54 PM   #38
basjoos's Avatar
Parts list: (2) 4'x8' sheets
Parts list:
(2) 4'x8' sheets of 4mm thick corrugated plastic (Coroplast)
(1) 20"x 10' roll of aluminum roof flashing
(1) box of 8-32x 3/4" panhead screws
(1) box 3/4" fender washers
(1) roll of white duct tape
(1) roll of heat resistant foil tape
(4) 14' pizza pans (for flat hub caps)
(2) tubes of caulk
Tools required:
Enough jack stands or blocks to suspend your car high enough to work under with all 4 wheels removed (be careful!).
Cordless drill
Drill and tap for 8-32 threads
Box cutter for cutting Coroplast
Tin snips for cutting flashing
Screwdrivers, etc.
aerocivic.com
Old 04-25-2006, 11:12 PM   #39
my dude was the first to
my dude was the first to ever say anything about plugging up the front of my car...
i passed it off...i should have listened...
BE ZEITGEISTED
Old 04-25-2006, 11:41 PM   #40
tomauto's Avatar
my dude
My Dude
Current Stable
Login inconsistencies mobile vs. PC GeneLeyden Fuelly Web Support and Community News 1 08-08-2008 01:22 AM
EV Smartcar zpiloto Electric and Solar powered 0 07-21-2006 04:48 PM
FE Test after Wheels, Spoilers, Added to HCH II: Pics & Techniques: tigerhonaker Automotive News, Articles and Products 0 07-14-2006 02:03 PM
METRO DISPOSAL XFi General Discussion (Off-Topic) 5 04-10-2006 08:58 PM
google earth MetroMPG Experiments, Modifications and DIY 13 03-14-2006 07:32 AM
