Check out the bottom of the civic hybrid - Fuelly Forums
Old 01-03-2007, 05:10 PM   #1
check out the bottom of my dad's civic hybrid. The Cd is supposedly .27, and it has a partial belly pan under part of the front of the car and near the back. It is suspiciously missing sections on either side behind the rear wheels.
Wouldnt there be less drag with these areas covered? it doesnt seem like it would cost very much to cover these areas, if they were already putting a plastic panel in that area. Any guesses why they wouldnt cover those areas?
At least on one side, it wouldnt be anywhere near the exhaust...even on the exhaust side, some improvement could easily be made. also, the lip of the rear bumper is a sharp edge that sticks out and overlaps the belly pan, it looks as if it would catch some air.
GasSavers_James is offline   Reply With Quote
Old 01-03-2007, 05:17 PM   #2
omgwtfbyobbq's Avatar
A couple wild guesses
-It doesn't matter. With air flow exiting near the low pressure trunk area anyway, there's no point to smoothing the air stream right before turbulent separation.
-They also may want to induce some turbulence right before the back of the car, so that some of the air flowing under the car will curve up into the low pressure area behind the trunk, and the separation of airflow over the top/sides of the car wouldn't be influenced as much.
Old 01-03-2007, 05:28 PM   #3
All I could make out from that picture was an upside down coil spring....
brelandt is offline   Reply With Quote
Old 01-03-2007, 06:59 PM   #4
yeah, sorry the pic is upside down. what you are looking at is the back corner of the vehicle, looking toward the rear wheel.
Could be that they left it like that to create turbulence. Initially, I would have thought that Honda would have optimized everything on the car, but after seeing the aero results of Phil Knox and Bajoos, I am starting to give everything a closer look.
Old 01-04-2007, 01:31 AM   #5
The Toecutter's Avatar
Another wild guess
-Some bean counter wanted to save about $1 off the materials costs without regard to the impact on the car's quality, basically telling the engineers to **** off.
Happens all the time in industry.
Old 01-04-2007, 11:09 AM   #6
Heh, yeah... VW uses plastic water pump impellers, plastic!
Old 01-04-2007, 08:48 PM   #7
I almost wonder if something is missing? The only reason i ask this is there is that empty circle ring thing, looks like it could be used to attach another plate, same with the bolt hole in the corner. The wheel spoilers also seem as if they were designed to work with more underbody. Hmmm
Old 01-19-2007, 02:15 PM   #8
Yeah,
Maybe honda will just start adding the panels in a couple years, as the MPG competition between the hybrids gets more intense??
I just wish they would have done a better job with it...I dont think my dad would like me putting coroplast under there!
Old 01-19-2007, 02:52 PM   #9
cfg83's Avatar
red91sit -
Maybe the circle ring thing is for a ground effects kit for a non-Hybrid Civic sedan. Maybe the new Si.
Old 01-19-2007, 10:49 PM   #10
Theres always room for improvement even on supposedly very efficient cars. A first gen Prius (97-99, never sold in US) owner in Australia was able improve fuel economy at 100kph from 42mpg to 47mpg with a simple front belly pan. You would think the manufacturers would have installed on it from the factory if they were trying to build the model of efficiency.
He went from this
To this
In the end every component goes through a cost vs benefit analysis. Filling in that area behind the rear tire will probably improve fuel economy by a point or two but it wasn't worth it to Honda. It might be to you.
I still find it outrageous that hybrids like the Prius and Civic don't come with rear wheel skirts from the factory.
Why Is there No App?! muffetmd Fuelly Web Support and Community News 8 03-11-2012 09:06 AM
Say hello to the Mighty Mira! Mighty Mira Introduce Yourself - New member Welcome 67 11-24-2007 03:19 PM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
Modifying exhaust to increase mileage? Matt Timion General Fuel Topics 15 01-07-2006 07:44 PM
