Cardboard box + duct tape = - Fuelly Forums
Old 10-18-2006, 05:26 PM   #1
Grill block!
had the box to use for a rad block and still had plenty left over so an hour and a half later i have a crude grill block on "Lil Silver" now.
there still two small opening by the turn signals in middle and i'm hoping that maybe they will be enough. this is just a crude temp thingy to see if it'll help with getting up to temp and possibly run a lil warmer. I only have a 5.1 mile drive to work and it takes almost 2 miles till fully warm (180 range)
didn't have anything to use to fasten it so i folded some duct tape over onto itself and made my own ties and tied it off to the grill.
gonna carry flashlight, and box cutter in case i have to do some roadside mods. also i found i can turn ac on then off and fan will keep running. between that and the heater i will be fine.
The mods have started!
Old 10-18-2006, 05:35 PM   #2
Send a message via AIM to molecule
sweet...i cant wait to getting around to my 'necessary' modifications of aerodynamics
though i think i will skip the use of cardboard...
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 10-18-2006, 06:32 PM   #3
kickflipjr's Avatar
It's a good time to put a grill block in because colder ait is on the way (Oh, I just saw you are from flordia. nevermind). It still helps in warm weather.
2008 EPA adjusted:
Old 10-19-2006, 12:10 AM   #4
philmcneal's Avatar
cardboard rocks, it took three rainy days to take my upper grille block down, and i still have the original bottom part! Whoo!
best of all its FREE
Old 10-19-2006, 10:55 AM   #5
Coroplast you guys! nearly the same weight, (probobly lighter than wet cardboard) and it lasts forever! I just got a MONSTER of a cigarette advertisement for my car
Old 10-19-2006, 12:55 PM   #6
if it work out with the cardboard then i'll end up using coroplast. especialy with the way it rains here in the summertime.
got caught behind some cars moving slow from a redlight and had to slow down whereas i usualy can make the light without slowing much. on way home seemed to warmup a bit quicker in slow speed driving (getting up to speed) and when i did get stopped and shut down on restart temp was a bit higher, but i'm gonna give it about a week or so of driving.
might end up having to use a partial rad block or underbelly pan between the bottom of the rad and the engine to get the full benefit.
Old 10-25-2006, 08:49 AM   #7
Most of my driving is a short 5 mile trip to and from work. car temp would be mid to low 180's and would climb a lil when stopped or slow moving.
today i went to the mall and got into some stop and go traffic and temp was nearly 220! that was a lil much so I turned heater on to get it down and found once moving about 30-35 mph was ok. the trip was about 10-15 miles.
I noticed that the instant mileage reading was showing a bit higher with the hotter temps and even the ait was showing higher too. temps here today are right around 70. air inlet temp was right around 90
those 5 mile work trips aren't getting the engine temp up, but not much else i can do. maybe block of the rad but then what about when i take longer trips??
Old 10-25-2006, 12:58 PM   #8
zpiloto's Avatar
You can get a block heater.
Old 10-25-2006, 02:17 PM   #9
LincolnW's Avatar
Check out the grill block that I just picked up!
LincolnW is offline   Reply With Quote
Old 10-25-2006, 02:40 PM   #10
forgot about that!
i'm gonna have to climb under neath and see if i can find the core plugs or a place to put on against the block
90CivicStandard: how much you boosting??
new user, how add base miles? bafxf Fuelly Web Support and Community News 8 06-06-2012 12:42 AM
EPA Estimate Banner kkoetter Fuelly Web Support and Community News 1 04-22-2012 01:37 PM
