brief guide - Fuelly Forums
Old 07-22-2007, 11:23 AM   #1
Arrow brief guide
To Change or Not to Change
When you modify your car in any way, you are changing the original design and the vehicle's overall characteristics. Sometimes that is a good thing, while other times it can lead to negative results. Below is a list of common modifications and their estimated change in percentage of the overall drag coefficient (Cd) of an average car. For example, the outside rearview mirrors add a two to four percent increase in the Cd. However, it should be noted that your results may vary.
Modification % Change
Lowering the vehicleby 30mm approx. -5
Smooth wheel covers -1 to -3
Wide tires +2 to +4
Windows flush with exterior approx. -1
Sealing body gaps -2 to -5
Underbody panels -1 to -7
Concealed headlamps +3 to +10
Outside rearview mirrors +2 to +5
Airflow into the enginecompartment +4 to +14
Brake cooling devices +2 to +5
Interior ventilation approx. +1
Open windows approx. +5
Open sunroof approx. +2
Roof-mounted surfboard rack approx. +40
from : http://www.europeancarweb.com/tech/0...de/tables.html
my English is bad, but I do not surrender!
fabrio is offline   Reply With Quote
Total Spent for 2010 is still not showing. fpage77 Fuelly Web Support and Community News 13 01-21-2010 03:48 AM
Does anyone wanna see a head swap DIY? SVOboy General Discussion (Off-Topic) 4 08-03-2006 07:05 AM
link to Garage from Gaslog? MetroMPG Fuelly Web Support and Community News 6 07-20-2006 09:26 AM
