Boat Tailing a Pickup - Page 3 - Fuelly Forums
Old 03-09-2007, 09:10 PM   #21
Snax's Avatar
One thing that both of you seem to have ignored with respect to the taller tires is frontal surface area. If you put a taller tire on, the frontal area goes up by half the diameter increase x the section width. So unless you lower the truck to compensate for the increased frontal area, the results will be skewed against what gain it might otherwise produce.
LiberalImage.com
I think, therefore I doubt.
Old 03-10-2007, 11:52 AM   #22
Snax's Avatar
I have just learned one nice thing about our 4WD: It has a 2" lift block installed over the rear axle which when removed levels the truck out.
I'm going to remove them and see what reducing that rear tire frontal area does. 2 x 2" x 10" = 40 sq in. that will be tucked up further into the wheel well. True, it's barely more than 1/4 of a square foot of reduction of exposed drag surface. Hopefully it will reveal some benefit however. (I'd argue it's in addition to frontal area, but that's probably not a technically correct way to define it.)
Regardless, I don't think my shell concept is going to happen for awhile if at all. I just don't have the time for it with all of my other projects going on. Most likely we'll just get a folding hard tonneau for now.
LiberalImage.com
Partial fuel-up - when do you reset your trip odometer? johnclayton Fuelly Web Support and Community News 2 07-30-2009 09:16 PM
Can I Manually Add Years Prior to 2006 mercury52 Fuelly Web Support and Community News 4 08-16-2008 02:52 AM
Ok, you Screw Balls! kozaz General Discussion (Off-Topic) 10 08-23-2006 06:06 PM
