belly pan advise please - Fuelly Forums
Old 08-05-2007, 02:59 PM   #1
holypaulie's Avatar
Greetings for everyone!
I'm thinking to install belly pan in my civic and I have a question. Is it better to cover exhaust pipe with thin aluminum metal sheet or slide this sheet underneath that pipe? I want to use this material, because it's a surplus.
Name:	civic underneath.jpg
Old 08-05-2007, 04:31 PM   #2
I think I would put the exhaust on the outside, just becuase I am concerned that the exhaust mught make other stuff overheat. But others have put the exhaust inside the belly pan and been okay....
Old 08-05-2007, 07:53 PM   #3
Member
I, too, have a civic that is going to get a belly pan soon, I think I'm going to cover the exhaust in the places where it's recessed enough to not melt the coroplast I'm using (1") away as I've seen so far... As for heat, I'm going to cut a couple of holes in the pan and let the venturi effect work it's stuff to draw hot air out. You could also make a few small scoops in the pan facing forward to move some air over the exhaust and take that hot air away. Drag of a small (1-2" wide?) scoop would certainly be negligible and the effect would be enough at slow highway speeds that you wouldn't have to worry about heat buildup.
varg is offline   Reply With Quote
Old 08-05-2007, 07:54 PM   #4
psyshack's Avatar
I did a engine belly pan on my Civic I just traded off. And the pan went with it.
It helped keep the engine bay clean. Which was what I wanted to start with. I couldnt tell it did a thing for mpg.
psy
09 HCHII, w/Navi
07 Mazda3 S Touring, 5MT
Mild Hypermiler or Mad Man?
Add driver to car already in garage, for shared car ssquid Fuelly Web Support and Community News 1 01-05-2013 01:10 PM
Civic VX miss under load oh95vx General Maintenance and Repair 54 07-21-2011 07:57 PM
Idle speed control valve zpiloto General Fuel Topics 19 03-01-2007 02:16 PM
LRR snow tires? GasSavers_Ryland General Fuel Topics 4 11-14-2006 01:40 AM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 06:08 PM
