Anyone experiment with spring heights to change aero? - Page 2 - Fuelly Forums
Old 09-24-2007, 06:18 PM   #11
Originally Posted by thisisntjared View Post
also where the shock mounts to the control arm is not a good place to measure ground clearance because it is unsprung. i would measure the lowest part of the sprung chasis to the ground. this would probably some cross member or something.
i have a solid axle in the rear, so ground clearance doesnt change until i air down the tires and the sidewalls get some noticeable flex.
ezeedee is offline   Reply With Quote
Old 09-24-2007, 07:20 PM   #12
or the differential in ezeedee's case
- a range rover would make it simple to test if it has manual control for fr/rr ht
- dunno if it does
Old 09-25-2007, 06:16 PM   #13
|V3|2D
thisisntjared's Avatar
hmm i didnt think of the rear axle as the point of measuring ground clearance.... i dont know what the standard is, but i wouldnt count it. if you do then a lift kit will not get you more ground clearance, only larger tires would.
Old 09-25-2007, 06:23 PM   #14
sorry, that's just the way the industry measures it... lowest point
people looking into lift kits will see a change in the angle of approach/departure and breakover
Old 09-30-2007, 12:44 PM   #15
oneinchsidehop's Avatar
Yep. Hot Rod Magazine
http://www.hotrod.com/techarticles/b...ips/index.html
Good article in parts. the gist of it: dropping the car is good for about a .01 improvement for every inch dropped. (I've heard that number a lot)
Dropping the front keeps air out and gives it a large space to expand: lower drag and squirrelly rear end.
Dropping the rear increases the venturi effect under the car (duh) so any belly pans become more valuable. Also creates (a lot) of lift in the front end. AKA suicide at speed. That would include 65mph with a gust of 50mph headwind.
Springs and ride hight effect the air under the car so much more than the air above that the changes in roof plane become almost unmeasurable.
Dropping works.
Air Dams work. if they're done right.
trunk extentions work
shaving works
chopping/channeling/sectioning works big time (reduction in frontal area)
Seems to make sense to me.
Oh, and no one at Bonneville (in the classes that allow it) run boat tails it seems. I wonder why? they do kamm backs though.
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 09-30-2007, 02:18 PM   #16
theclencher's Avatar
1L doesn't have boattail either.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
elg's Project zpiloto General Fuel Topics 2 03-03-2007 07:47 PM
