Air Dam and Bellypan Material - Fuelly Forums
Old 04-19-2008, 05:03 AM   #1
Speedway motors has some sheet plastic that has a lot of uses. Of course it won't tolerate much heat. It can be permanently formed with careful use of a heatgun although this does destroy the gloss finish.
http://www.speedwaymotors.com/p/1557...d-Plastic.html
GasSavers_rayjay is offline   Reply With Quote
Old 04-30-2008, 10:11 AM   #2
be_good_customs's Avatar
can they really be made into a belly pan
be_good_customs is offline   Reply With Quote
Old 05-02-2008, 10:49 PM   #3
BamZipPow's Avatar
Send a message via AIM to BamZipPow
If you use some bracing...yes, it can be. Just have to be careful around the catalytic converter and down pipes...
BamZipPow is offline   Reply With Quote
Old 05-03-2008, 06:06 AM   #4
Any sources of coroplast?
(I'm thinking the R/C aircraft suppliers probably sell it...not sure how competitive their prices are, though)
Old 05-03-2008, 02:49 PM   #5
BamZipPow's Avatar
I picked up a sheet of 4x8 4mm white at the local sign making place. Got it fer just under $40 with tax.
I did find some thin plastic sheets that's similar to PVC at Home Depot fer $30. It's called 0.090 FRP 4x8 wall panel white. It's kinda smooth on the backside and definitely textured on the front side with various bumps. You can find it in the paneling section. Not sure how well it would hold up though...
Old 05-03-2008, 03:17 PM   #6
BamZipPow's Avatar
FRP = fiber reinforced plastic
Don't know if it will hold up to UV rays as I'm not finding information on that. Looks like it's primary use is in commercial bathrooms and public areas. It's supposed to be fiberglass free...although some sites are listing the F part as fiberglass...go figure.
Old 05-04-2008, 12:53 PM   #7
In what section? I think there are regional differences in what they sell.
On another board awhile back, someone told me that he was purchasing FR4 (fiberglass "sheet") at Home Depot. FR4 is very similar to circuitboard substrate.
Needless to say, the HD stores in my area didn't sell it.
Old 05-05-2008, 02:25 AM   #8
BamZipPow's Avatar
I found it with the wall (wood) paneling stuff. It was sitting on the bottom underneath the wood stuff...kinda by it's lonesome self. It's supposed to be pretty resilient as it's used in commercial wall coverings. I'll try to git the SKU number tomorrow and post that up. Maybe the "friendly" customer section would help you located it in their store...
Old 05-06-2008, 07:46 AM   #9
BamZipPow's Avatar
Talking
Here's 2 piccies of the SKU and the item number printed on the FRP:
Panel imprinted information:
788594490185
Wall Liner 4x8
Panel White 0.90
Old 05-06-2008, 08:35 AM   #10
Nice pic.
Was at H-D yesterday, didn't find it.
Next time I'm there, I'll ask.
BTW, where are you geographically? Are you in a hurricane-prone area?
