Aerodynamic wiper blades ? - Fuelly Forums
Old 03-11-2008, 06:34 PM   #1
holypaulie's Avatar
Question Aerodynamic wiper blades ?
I was wonder if those http://www.extremestyling.com/HONDA-...B000EDJHPW.htm wiper blades with aerodynamic spoiler would decrese windshield drag. What do you guys think about them. Are they worth it?
Old 03-11-2008, 06:56 PM   #2
They are designed to increase the down force on the windshield at higher speed thus creating MORE drag - probably works the wiper motor more too. From what I have seen it looks to me like the new Rain-X wiper blades are about the best thing going - really low profile - no "suspension bridge work" holding the blade - even pressure along the entire blade - just a bit expensive.
Old 03-12-2008, 12:46 AM   #3
lunarhighway's Avatar
i've got valeo flatblades retrofitted to my car. looks nice especially since my wipers are right in the airflow.
they certainly look as if they would disturb less air than a standard wiper, but i doubt road testing could reveal any impovements. they have a small integrated spoiler on top, and as such they do wipe very well at higher speeds.
on the other hand they're less flexible, my left one does touch the outer curved corner of the windshield untill it moves up a little higher. might have to do with the fact the wipers still use the standard arms. i changed the angle.
they cost about 2 or 3 times as much as standard ones but imo they're woth is as they're still not showing any defects even when the change indicator that slowly colors yellow over time sugests they should have been changed long ago.
just remember your wipers sit in a high pressure pocket so they're not going to cause they much drag as it would seem.
Old 03-12-2008, 07:36 AM   #4
I put some low profile "aero" blades on Marvin... can't say they really do much for F-E. They might have improved things an iota, because at highway speed, regular blades were jumping about at the base of the screen a bit, and trying to use them at any speed over 50 was a challenge, especially with a bit of headwind. These however stay on the screen and actually wipe at 60ish.
Old 03-12-2008, 07:41 AM   #5
basjoos's Avatar
I built a small sheet metal windshield at the base of the hood to keep my wipers out of the airstream. Prior to this when driving through heavy fog, the fog would deposit streaks on the windshield glass that could be traced back to the slots in the wiper frame, from which I deduced that the airstream was passing through the wipers (and creating drag).
aerocivic.com
Old 03-14-2008, 12:54 PM   #6
Hateful's Avatar
Send a message via AIM to Hateful
I screwed some soda bottles to the plastic vent cover and used a cigarette lighter to melt waves into it. This may make turbulence worse than the wipers,but I'm thinking it will break it up;making it less harmful. I don't know how much wipers can hurt FE anyway,but every little bit helps.
Hateful is offline   Reply With Quote
Old 03-14-2008, 04:22 PM   #7
s2man's Avatar
Rubber molding glued to the front and back of the hood. It was nice and flat to start with, but the compound curve of the hood edge caused it to buckle and get wavy (or was that where I had the clamps?) . I guess sheet metal, ala basjoos, or ABS, ala autospeed, would be best.
Roll on,
S2man
s2man is offline   Reply With Quote
Stretching the shrinking dollar bowtieguy General Discussion (Off-Topic) 78 04-08-2012 02:21 PM
Why doesnt my car show up under 'browse vehicles'? frederic73 Fuelly Web Support and Community News 4 06-17-2011 04:00 AM
Tire sizing odometer modifier? BDC Fuelly Web Support and Community News 10 07-25-2009 09:59 PM
iPhone interface - I missed a fuel up check box is distorted funkd00bi3st Fuelly Web Support and Community News 2 08-13-2008 10:19 AM
Sparrow Electric Car Matt Timion Electric and Solar powered 11 06-27-2006 09:50 PM
