Originally Posted by Mighty Mira
Consider the front end of some torpedos:
That's fascinating, it could simplify matters to call into service the bottom of a cylindrical container...
I tried a tiny 1.5" convex mirror inboard, and it did the job satisfactorily. I found it even better when mounted further up the A pillar toward my head, so my strategy is changing-- I think I'll mount an inboard mirror for visibility's sake, then have a doppelganger outside to deflect unwanted attention.
Idea 1- cut the profile of the stock mirror out of it's housing entirely, leaving a thin foil (no pun intended) shaped deceptively like a standard mirror but minimizing drag.
Rely on the optical illusion of seeing the road ahead through the mirror, or a clever paint scheme inside the housing, to make it look authentic. Chance of success is thin...
Idea 2- Make as aerodynamic a shape possible to protrude from the side of the car, and cover the tapered section with mirrored vinyl to give the impression of an unorthodox but
undeniably present mirror.
I think the latter sounds more likely, even if... unlikely.
