Accent Grille Block Material Suggestions? - Page 3 - Fuelly Forums
Old 03-27-2009, 10:01 AM   #21
the larger cut off wheels do work better but the potato chip cut off wheels were on hand and came in the accessory kit with the dremel.
By "potato chip" you mean those super thin disc type wheels, right? Don't own a Dremel.
co de pen den cy
Function: noun
Date: 1979
Old 03-27-2009, 11:00 AM   #22
Yeah, he means the super thin abrasive discs. The diamond wheels I was talking about are the same exact size and shape, not larger; they're just tougher, made of metal.
$4 @ Harbor Freight: http://www.harborfreight.com/cpi/cta...emnumber=31501
Old 03-27-2009, 11:02 AM   #23
Those as fragile as they look? I had fun grinding some welds on my homemade rip fence before I bought an angle grinder. I used my bench grinder. VERY good arm workout!
co de pen den cy
Function: noun
Date: 1979
Old 03-27-2009, 11:05 AM   #24
The diamond-coated metal ones I posted above are tough as nails, I haven't managed to hurt one yet and I abuse the hell out of 'em. You can cut with them, patiently or by shoving too hard; you can also grind with their surface.
The cheap abrasive ones that come with every dremel, usually in a can of a few dozen, are absolutely useless, I don't know how anyone cuts anything with them. I only have to look at them sideways and they break.
Old 03-27-2009, 11:08 AM   #25
GasSavers_BEEF's Avatar
those chip disks are actually better than the ones I use. mine are the same material thourghout. just a hole in the center.
depending on what you are cutting, it will actually burn the disc down. cutting some metal tubing, I actually used one up before I broke it. I think that is a first (for me anyways). if you put any pressure on it at all from the side or twist it in the material it will snap. I usually break it getting it out of the drill or when I go to get it for another project. you don't buy one though, you get a small container with like 25 or so in it.
I have seen the metal ones, they are nice and the one I saw was much larger. not sure if my dremel would handle it. I have the really cheap one. I think it is a lite?
*edit* cow, you beat me to it. those are the ones and they are difficult to work with but I never think about it when I am in town to get any of the others.
Old 03-30-2009, 12:00 PM   #26
How thick does grille block material reasonably have to be if well supported behind it? Actually, let me be more specific: how thin could it be? I've got some weird ideas for adjustable grille blocks and the moving part would have to be flexible if any curving of the block were required.
My front grill and the horizontal bar and Hyundai logo can all come out pretty easily, although I don't want to do anything that can't be reversed in less than 15 minutes or so in case I need to use my warranty. I plan to keep the tools needed to do so in the trunk just in case.
co de pen den cy
Function: noun
Date: 1979
Old 03-30-2009, 01:55 PM   #27
Duct tape works as a temporary grille block. As long as the material you choose is structurally sound at that thickness you're ok.
Old 04-01-2009, 02:49 PM   #28
Turns out I do have a temp sensor after all! Seems pretty obvious now that I've spotted it, so I'm not sure how I missed the description in the manual. Oops. It displays a red thermometer if the temperature of the coolant gets above 253.4 +/- 37.4 F. So at least I don't need to bother rigging anything to the fan. Obviously I can be pretty vigilant when testing, but I sort of wish it had a buzzer in case later on it comes on and I don't notice it right away. I guess I could rig one and I'm pretty sure I have a couple 12VDC buzzers lying around.
co de pen den cy
Function: noun
Date: 1979
Old 04-02-2009, 12:58 PM   #29
Hey,
I have the 2008 Accent. I bought some 1 inch pipe insulation. The grey foam kind and cut them to fit in the gaps. The fit snug and they stayed stuck as they expanded. They look pretty good too.
I did it because I am in Canada and wanted to block the cold air coming into the engine compartment. Worked like a charm! They stayed in place all winter. I have a ScanGuage and used it to watch the cold ait intake and engine temps. The engine warmed quickley and stayed warm longer. Cost me $7, 5 minutes to install and my local hardware store had them in stock.
Eyeteaguy is offline   Reply With Quote
Old 04-02-2009, 01:12 PM   #30
Interesting idea! I have some of that lying around.
A slightly more refined version could involve cutting some foam to fit. Think I chucked some 2" foam board but I'll take a look.
co de pen den cy
Function: noun
Date: 1979
Log and Facebook MPG issue gherkin Fuelly Web Support and Community News 2 08-06-2011 03:12 AM
Tires - How Narrow Should I Go? Vladi General Fuel Topics 8 05-28-2008 01:29 PM
98-04 Regal GS Aero mods ophidia31 Aerodynamics 2 05-24-2008 04:49 PM
New Low Cost Solar Panels Ready for Mass Production cfg83 Automotive News, Articles and Products 6 09-25-2007 11:04 AM
Yeah wont be driveing for a while Hockey4mnhs General Discussion (Off-Topic) 29 04-09-2007 07:29 PM
