? about Golf ball dimples - Page 5 - Fuelly Forums
Old 12-16-2008, 06:35 PM   #41
1/4 inch high closed cell foam draft insulation tape.
Old 12-17-2008, 05:36 AM   #42
101mpg's Avatar
Don't care if drag is increased - we're trying to increase MILEAGE.
Shark skin is "dimpled" or otherwise non-smooth. In rowing, the new carbon fiber shells have shark skin type coverings instead of smooth over fiberglass or wood. Why? They decrease drag through the water. Whether it's NET drag or immediate drag, I honestly don't know why we'd care.
Same principle applies here. By the way oranges are also aerodynamic with their "orange peel" skin. They don't normally move but if you've ever seen a cruddy paint job with "orange peel" (water in the paint usually), this type of paint job helps aerodynamics. Decrease cD for those who care.
So if dimpling, shark skin or orange peel effects help aerodynamics, you'll be helped with this type of covering. Anything that has a NET effect of getting the car through the air with less effort, even if it increases drag directly ON the skin but the surrounding air becomes net slipperier, then I say use it.
Old 01-25-2009, 09:24 PM   #43
bzipitidoo's Avatar
The Corbin Sparrow uses dimples at the trailing edges. Look at the body above the rear wheel, and the back of the front fender. Here's a pic:
http://myersmotors.com/im1/home_full/full_2.jpg
bzipitidoo is offline   Reply With Quote
Old 01-26-2009, 05:57 AM   #44
Snax's Avatar
Never noticed that before. Seems to suggest that they may need to work under more dynamic orientation to the direction of travel. I have read of owners finding themselves pointing the wrong way after braking and turning too quickly!
LiberalImage.com
I think, therefore I doubt.
x-guage LxMike General Fuel Topics 1 02-20-2008 11:06 PM
Hey Guys!, 92 civic vx here. coastmonster Introduce Yourself - New member Welcome 14 12-12-2007 09:48 AM
A New Tool for MPG Testing Bill in Houston Experiments, Modifications and DIY 7 06-12-2007 05:32 PM
Proper shape of a belly pan jdham137 Aerodynamics 4 04-29-2007 10:36 AM
Solar boat MetroMPG Electric and Solar powered 1 08-16-2006 10:37 AM
