Two-Stroke oil - Page 2 - Fuelly Forums
Old 06-09-2008, 05:38 AM   #11
GasSavers_SD26's Avatar
It's not the sulfur that was the lubricant. The the process that removed the sulfur removed the parts of diesel fuel that lubricated everything.
It's increased the cost of making diesel and as for a placebo affect? I think there was a study done when the idea was proposed that said it would increase the cost by $0.50 a gallon in addition to reducing the mileage of diesel vehicles.
Supplimenting fuel is now important.
Dave
Old 10-29-2010, 05:39 AM   #12
Re: Two-Stroke oil
As someone out here has stated that sulfur is not a lubricant is incorrect as it is a very good lubricant and when it was some 5000 ppm years ago in diesel fuel it was great at stopping wear. When they started to remove it along with it they removed the BTU'S of the diesel. The BTU's gives you power and also fuel mileage. When it dropped down to some 500ppm of sulphur max.,diesel owners started having problems with their fuel injection systems and injectors, big problems as they started failing in no time. Oil companys had a big problem for a time because of it too.
Diesel2 is offline   Reply With Quote
Old 12-20-2010, 07:57 PM   #13
Re: Two-Stroke oil
Very true. VW sent new car owners a pamphlet on why they should buy this bottle of "diesel fuel lubricant" when the ulsd came out.
As far as milage, in 2007 the emission controls added to the diesels to make them pass the more stringent rules is what cut the milage. (from 20% egr to about 60% among other things) If you pull the dpf off and recalibrate the computor to reduce the egr settings (and mod the inj pulse,blah,blah,blah) you can jump from 14mpg in a 08 f-250 to 21mpg. (don't ask how I know) hehehe
dieselmech is offline   Reply With Quote
Help! AlfieGT Fuelly Web Support and Community News 1 05-23-2011 12:35 AM
Mercedes Stop-start technology lunarhighway Automotive News, Articles and Products 0 07-30-2007 04:46 AM
A RAV4 to go with the Prius? krousdb General Discussion (Off-Topic) 31 12-30-2006 05:32 AM
Diesel chip Sludgy Diesels 10 12-10-2006 08:44 PM
TPS Will a 88 Civic DPFI TPS Work on a 92-95 D15z1 8Civic8 General Maintenance and Repair 2 11-09-2006 11:12 PM
