Newby diesel advice/info - Fuelly Forums
Old 08-01-2009, 02:17 PM   #1
thecheese429's Avatar
I have had restoring my Jeep in the back of my mind for a while, and have also been toying with the idea of sticking a diesel in it. While I know this won't happen any time soon, I love info. I plan to buy the engine (probably used, because of $), but I'm not sure what model/year I should get.
I want something that gets decent mileage if I baby the throttle, but can do moderate hauling if I hammer it. I am also intrigued by the idea of a "no electronics" engine, and just use mechanical controls (EMP-resistant!).
Another feature that lures me to diesel is the fuel compatibility. I have heard that a diesel (namely an old diesel) can run just about any fuel, from vodka to kerosene. I might have it rigged with a dual-fuel switch, to run propane or liquid fuel.
Again I have no experience with diesels (unless moving trucks count ) so any info/advice would be appreciated. What model/year diesel do you have? How has it held up over the years? What kind of maintenance do you need?
-Becoming the Archetype
thecheese429 is offline   Reply With Quote
Old 08-01-2009, 07:29 PM   #2
Try 4btswaps.com for a whole bunch of crazy folks who do this sort of thing.
Personally, I'm getting quite addicted to the idea of a 3.3BT in an older Cherokee... 30mpg+ is reported.
Old 08-02-2009, 06:45 AM   #3
Well, if you plan to pick an old Cherokee, be sure to get one from pre-1987. That was the year that Chrysler took over and ruined the whole shebang.
This 86 seems to take a beating and come back for more, though. I think its a good choice.
And, yes, 30+ MPG in a small pickup catches my attention as well
Old 08-02-2009, 01:27 PM   #4
Mike T's Avatar
Old Renault diesels fit perfectly, such as the one in the Le Sharo Winnebago. In Europe during the Renault/AMC era, the CJ had a turbo diesel option.
2008 Mercedes-Benz B 200
Mike T is offline   Reply With Quote
Old 08-02-2009, 06:40 PM   #5
Jetta90GL's Avatar
They did this on Xtreme 4x4, except it was a Suzuki Samurai. They used a VW TDI diesel engine, and converted it to run on WVO.
http://www.powerblocktv.com/site3/in...-03&ep_sea0801
There is a rare version of the TDI that is all mechanical injection.
Jetta90GL is offline   Reply With Quote
Old 08-10-2009, 08:29 PM   #6
I have been looking at my options, and here are a few more details.
I am fairly sure I want to stick with a 3 or 4 cyl, with no more than 3.3 or so liters. I was looking into a 4bt or 6bt, but found out that the 4bt weighs about 700 lbs! The Comanche was not built with very even weight distribution, so I want to stick with something a little lighter (than the 4bt).
I'll also want one from pre-90s because I want as much user serviceability and mechanical apparatus as possible.
One of the reasons that I am looking at an engine swap at all is because I want more power from a smaller engine. That's partially induced by the lack of power from the current power plant. I can't go over 60 up a slight grade without dropping into 4th! That's not helped by the bigger than stock tires.
Will a TX inspection station be able to give me a performance analysis? I would like to know how much power I'm getting from this engine, so I can try to look for something with ~150-200%. I'm also curious as to the power curve. Could I get that at a jiffy lube or would I need to call around?
I was looking at an 80s VW TDI but never looked much into it. What kind of HP and torque can I expect from one of those? I don't really want a heap more power, but just a little more than what I have now.
Mike: I know that the MJ/XJ also had a 2.1 diesel (not sure if turbo) in the states. Was that a reliable/economical/powerful engine? How hard is it to get a renault engine/parts in the states?
I guess that I am also lured in by the idea of getting great towing power AND great MPGs at the same time. Is this realistic? As you can see, I am not too partial to any one engine, but I want to stay away from Ford/Chevy/GMC.
Old 08-22-2009, 10:16 AM   #7
During my repair, I found that this jeep has been in an accident. Although the damage is superficial, I don't think I'll be keeping this truck forever. I am a perfectionist, and if it isn't perfect (or I can't make it so) I don't really want to try. But I plan to keep this truck for awhile, and sell it when the time is right.
All that to say that I don't think this jeep will be the lucky winner of a new diesel engine. I might get a 60s small pickup and do it with that. That would be easier, anyway, because it wouldn't be a **shudder** unibody... and I could weld mounts right onto the frame.
OTOH, Here's a video of someone who has done something similar to what I want:
(He must be an Okie)
http://www.youtube.com/watch?v=ZxnU3F6EM-0
Old 09-23-2009, 12:39 PM   #8
VERY IMPORTANT: If you swap engines, SWAP TRANSMISSIONS TOO!!! People who swap only the engine are invariably disapointed when they keep the gas transmission- VERY IMPT to have your transmission matched to the diesel, as the whole engine dynamics- RPM's, torque, most efficient HP range- are VERY DIFFERENT between gas/diesel!
Squirrl is offline   Reply With Quote
Old 09-23-2009, 05:03 PM   #9
Thanks for that advice, I'll be sure to keep that in mind for whenever I DO (sometime) get a diesel vehicle.
As far as the maintenance goes, the hood now has primer on it and is awaiting... another coat of primer, colour, then clearcoat.
civic sedan or coupe which is better for FE yzfdallas General Fuel Topics 5 02-21-2008 07:59 AM
Amazed by the SGII GeekGuyAndy General Discussion (Off-Topic) 7 08-19-2007 12:25 AM
Scan Gauge 2 How it works popimp General Fuel Topics 15 06-20-2007 06:46 PM
PepsiCo Connections? SVOboy General Discussion (Off-Topic) 3 10-12-2006 05:52 PM
