Good Mod for Diesels - Fuelly Forums
Old 01-04-2008, 07:07 PM   #1
Get a pyrometer. It measures exhaust gas temperature. The best place to put the pyrometer is before the turbo.
In general, if you can keep EGT below 600 degrees, you will get good MPG.
2000 Ford F-350 Super Cab Pickup
4x2, 6 speed manual
Regeared to 3.08:1
4 inch suspension slam
Aero mods: "Fastback" fairing and rugged air dam and side skirts
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Big Dave is offline   Reply With Quote
Old 01-05-2008, 09:01 AM   #2
Great tip on the pyro. Pyro is also good to let you know if you are pushing your turbo to hard when you aren't driving for FE.
I am a mechanic for a small construction company and I have had to replace a couple of turbos on 3406 Cat engines due to long grades, heavy loads and heavy foot on the go pedal while ignoring pyro. CAT parts are big $$$. Not to mention towing a 80,000 rig off the mountian, lost loads...
Cheap insurance if you pay attention to it.
chrlk is offline   Reply With Quote
Old 01-05-2008, 10:38 AM   #3
Nice thing is that these are commonly available guages. Mine is an AutoMeter.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Old 01-05-2008, 08:41 PM   #4
Little bit of water injection would also help clean things up and reduce your EGTs
Old 01-06-2008, 05:41 AM   #5
GasSavers_SD26's Avatar
How far from the cylinder head did you mount your pyro sensor?
Dave
Old 01-06-2008, 09:31 AM   #6
My pyrometer is about 8 inches in front of the turbo, downstream of the "Y." It reads an average of the EGT of the eight cylinders.
Aircraft pyros read each cylinder. Pilots are very vigilant about engine trouble when they have only one engine.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Old 01-11-2008, 04:45 PM   #7
With the high zoot rebuild I had done on my auto-magic tranny I can't hardly get it to shift if I drive with the EGT's under 600 on my Dodge.
On a more exciting note, I Pulled a long steep grade last month with GCW at ~14k. 28psi boost and EGT never went over 1100.
By the way, Big Dave, I love what you are doing to your truck.
philp100 is offline   Reply With Quote
Old 01-13-2008, 06:54 PM   #8
I agree with Big Dave. Exhaust temp is a good indication of running effectively for best gas mileage on a diesel engine. If you run too rich, pyro goes up, run too lean and the pyro goes up. Keep it low and safe and effecient and gas mileage will be your reward!
I wish our school busses had an EGT gauge!! I swear, some of these drivers never let their foot off the go pedal till they pull back into the lot! The same school bus can get 5 mpg with one agressive driver, yet 7 mpg with a different and more sane driver but on the same route!!
Old 12-08-2009, 02:02 PM   #9
Pyrometer: useful in an naturally aspirated diesel?
Hello,
Can you state what sensors or gauges you recommend to install in a naturally aspirated diesel in order to improve fuel yield?
Pyrometer is one of them?
Any other one?
Thanks in advance for sharing your knowledge.
OldBeaver
(Newbie)
Mercedes 300E converted to diesel.
OldBeaver is offline   Reply With Quote
Old 12-31-2009, 03:28 AM   #10
I know on my 24V Cummins vp44, a fuel pressure gauge is a must. The fuel cools the injector pump. Also for the auto magic A/T temp gauge, if your truck is doing some heavy pulling that is!
Dave
94 vx
93 del Sol
93 Miata
92 Prelude Si
Dave's Civic Duty is offline   Reply With Quote
km/l possible? Scottrates Fuelly Web Support and Community News 4 10-05-2010 11:14 PM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 01:15 AM
RSS feed for Fuel Tip Page randomic Fuelly Web Support and Community News 3 08-22-2008 11:55 PM
WTB: 92-95 civic hatchback GasSavers_McGee Wanted to Buy 4 07-25-2007 03:22 PM
$80 civic vx tranny in MN GasSavers_Ryland For Sale 0 05-15-2007 02:32 PM
