Chip contest - Page 3 - Fuelly Forums
Old 02-17-2008, 07:23 PM   #21
DRW
WOOHOO!!! I WON!
Sorry about the drop in mileage, my guess was based on lousy wintertime weather. Are you sure the weather didn't have an effect?
I promise I'll use the money for a good cause, probably get a little more coroplast or some screening to complete my underbody cover. Maybe try a rear wing or wheel fairings.
or beer! hahaha
Dave W.
Old 02-18-2008, 02:32 PM   #22
Ya gotta send an email with your name and an address to send the check.
Old 02-28-2008, 07:01 AM   #23
I bet a good way to get better FE on these big PSD's would be to have another gear. Like a 2 speed dif. The first for towing and the second for running unloaded. The higher gear would keep the RPM's down and simply use the tourqe. The truck would feel a bit sluggish off the line, but one rolling you wouldn't notice.
Honestly, these things have more power than is needed. I know that there are kits that provide an extra overdrive. About $4000k for it. Even if it helps FE a little you wouldn't save a $.
https://www.maxxgraphix.net
maxxgraphix is offline   Reply With Quote
Old 02-28-2008, 07:11 AM   #24
GasSavers_SD26's Avatar
No, just some people aren't pulling enough. And one can't complain about the resale. Back to $$.
Dave
Old 03-01-2008, 02:08 PM   #25
Why doesn't Ford offer a 3.23 or 3.42 diff? The Powertroke has more power than God, it doesn't need 3.73's, or even a 2 speed axle.
Old 03-01-2008, 02:27 PM   #26
Top gear on the E4OD and the R4100's were a .71 ratio. 3.55's are tall if you're gonna pull a 24ft enclosed trailer, or larger, loaded up for any regularity. 3.73's are a nice compromise.
I don't know exactly what the new transmissions have for their top ratio, but I'm betting its very similar to the previous, but it has more gears now than four.
Dave
Old 03-28-2008, 06:03 AM   #27
I've got a Sniper Diesel Tuner kit on the way. I think you can program a lean burn for when you are running unloaded. You can also load a tune into a chip. So this way you can have one in the ECU and one on a chip. Econo / Towing
http://www.snipertuning.com/new/
I'll post back after a few trials.
Creating a Switch to Shut Off Cylinders on the Fly SVOboy General Fuel Topics 78 10-08-2009 07:13 AM
Fuel cut-off threshold speeds GasSavers_Rotareneg General Maintenance and Repair 10 08-13-2007 06:27 AM
Search for members zpiloto Fuelly Web Support and Community News 2 11-30-2006 05:01 PM
Hello, from Gary Gary Palmer Introduce Yourself - New member Welcome 17 06-02-2006 05:42 PM
How I made my ****ty auto torque converter lock up without an auto ecu SVOboy Transmissions and Running Gear 17 03-29-2006 07:54 PM
