Originally Posted by Sludgy
Well, I've tried downsizing tires on the Blue Beast, from 265-75R16 to 235-85R16. The new tires are a hairsbreadth taller than stock but narrower. I haven't seen much improvement in mileage.
I have been thinking of going in the opposite direction. BFG makes huge all-terrain 305-75R16 tires. Now I know that the tread on these tires is not aerodynamic and they are heavier. But it will effectively gear the truck about 8% lower for a given speed. The effective axle ratio will go from 3.73 to 3.47.
What's the group's opinion? Will big mud tires make my mileage go up or down?
To echo the others...down 4sho. you could try a 255/85/16. Be careful of the wider taller tires. Any overdrive gains are negated by the increased RR and weight.
I've got a '97 PSD 1ton. Since 2002 I've increased the fuel mileage doing a number of things specific to this vehicle.
Learned to drive speeds that lock up the torque converter. Mine locks at 45mph but after it locks it won't unlock until I drop below 40mph.
Went from 285s to 265s at 80psi.
I added an open element intake (tymar),
a chip made a big diff too. Weird enough the best fuel mileage gain is on the hottest setting of the chip.
Removed my bug guard (not really vehicle specific).
and I don't drive on trips of less than 10miles unless I have to. The owners manual actually says not to cause the motor won't get up to operating temp.
I use a block heater on a timer for at least 1.5hours before starting it on days I have to drive it (generally only in the winter). Cold truck really gets back mileage.
One other thing...I try to never get the rpms over 1600. I believe that my motor has 425ft/lbs of torque at 1600rpms
Good luck with it.
PS The best fuel mileage I ever got was a trip to SD from WA in a really hot July a few years back I was getting about 560miles before each fillup whereas usual around here is 425 before a fillup. Extended freeway driving in hot weather seemed to be the ticket (I was generally doing about 80mph too as the montana speed limit signs are just there to satisfy the feds
