Why is AT less efficient? - Page 2 - Fuelly Forums
Old 02-26-2007, 07:06 PM   #11
With the 4T65E-HD (4-sp automatic) I can control shift point, TC lock-up, and other parameters with my tuner.
I am sure there are ways to adjust settings on most electronically controller automatics.
For the older automatics (example: 92-95 Civics) has anyone tried changing gears to lower the highway cruising RPMs?
GasSavers_Lincoln is offline   Reply With Quote
Old 02-26-2007, 07:17 PM   #12
cfg83's Avatar
diamondlarry -
Originally Posted by diamondlarry View Post
I'm REALLY glad I have a manual.
My brain just ain't working right. I thought you meant manual as in Haynes or Chilton or something.
Old 02-26-2007, 09:34 PM   #13
Speaking of Manual
I located the shop manual and noted that I can override the TC engagement through manually engaging 1 or both of the 2 TC lockup sensors via 5V power. Judging by the schematics, it may bypass the VSS and TPS to make the final decision to lock up through the switch override -- I'd just have to be mindful of speeds and coolant temps to prevent further damage to the trans. Of the 3 settings of full, partial, or zero lockup, one sensor allows partial, and the other engages full and uses the Hill/Fuzzy-Logic adaptive computer for shifting (argh). So, during the colder months, perhaps 2 toggles could manually engage these at lower TPS settings once the speed allows. Purely theory.
I'll tell ya, that 50-page section on the automatic transmission looks more complicated than open-heart surgery. Sheesh.
If you're stuck with an auto, I reccommend finding a shop manual that describes exactly what parameters the transmission requires. Further inspection could perhaps find a way to take control of that vicious dictator: the Transmission Control Module.
Old 02-28-2007, 01:02 AM   #14
caprice's Avatar
Wow thanks for all the responces! I could swap in a Camero 6 speed transmission. I've had two 5 speed manual cars before. On both, I notice if I short shift, I can get better than the EPA highway milage, in the city. I have a 700r4 transmission in my caprice, I would have trade in the newer electrically controlled one and program differnt shift points.
David
85 Chevrolet. 30 MPG or bust!
caprice is offline   Reply With Quote
Old 02-28-2007, 03:36 AM   #15
skewbe's Avatar
A camaro 6 speed will cost you more than a metro
Standard Disclaimer
Old 02-28-2007, 12:24 PM   #16
cfg83's Avatar
caprice -
I googled "camaro 6th speed manual gear ratios" and found this :
1996 CHEVROLET CAMARO
http://www.media.gm.com/ca/gm/en/pro...996Camaro.html
(Paraphrased from URL)
TRANSMISSION : 6-speed manual w/overdrive
Gear Ratios:
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th 0.74
6th 0.50
Reverse 2.90
Old 03-01-2007, 01:28 AM   #17
caprice's Avatar
and with my gear ratio and tire size, at 75 MPH the engine would be turning 1500 RPM 50 MPH is 1000 RPM. With the low end torque of a 5.7 liter engine, I'd have no problem If I want a little passing power, I could just down shift.
http://www.f-body.org/gears/
David
Old 03-01-2007, 01:51 AM   #18
caprice's Avatar
It would be cool driving a huge car with a manual short throw shifter. Like the one in Underworld.
David
Old 03-02-2007, 07:09 AM   #19
brucepick's Avatar
synthetic tranny fluid?
How about synthetic transmission fluid?
I've seen some posts elsewhere saying that's definitely the way to go.
Any benefits to FE, or just that it lasts longer and probably protects the tranny better?
Old 03-02-2007, 07:14 AM   #20
From a FE perspective, the main benefit of synthetics is their cold performance (viscosity). They don't thicken as much as mineral fluids as temps drop.
People who live in a year-round warm climate would probably see no FE benefit from synthetic use.
Note that no major synthetic brand claims fuel economy improvements with their use.
Kickstarter - Video Series on Better MPG andyrobo General Fuel Topics 3 03-29-2013 07:49 AM
Making Fuelly more "Shoping" friendly Mashurst Fuelly Web Support and Community News 3 07-16-2010 12:46 AM
Potential Savings Per Fuel-up Suggestion Razinhell Fuelly Web Support and Community News 4 10-30-2009 07:03 AM
New cars don't get along with fuelly mlocklear Fuelly Web Support and Community News 5 06-13-2009 03:27 AM
