When to make it shift - Page 2 - Fuelly Forums
Old 12-13-2006, 10:53 AM   #11
Originally Posted by Hockey4mnhs
I?ve been reading lots of sites including this one for the past two months. I really try hard to have good mileage. I moded the intake to a K&N which i think may help. Cruse control is a absolute must when i drive because i have 18 mile each way commute on almost all highway. Still i have never broken 28/29 mpg. You guys are getting 2x that. Please help with any suggestions
don't look at the numbers other are getting unless it with same car and trans.
find what the epa rates your car at and work towards beating those. makje sure engine is tuned up, check the basics . tire pressures set at what?? any extra weight you don't need in there. stuff like that. do you have a tach> what rpm's does it show at speed??
Old 12-13-2006, 12:29 PM   #12
Hockey4mnhs's Avatar
at 45 i my rpms are at 1500 is that to low or should i go 50 and have the fuel run not as rich.
Old 12-13-2006, 12:35 PM   #13
omgwtfbyobbq's Avatar
The slower in top gear the better. Usually...
Old 12-13-2006, 12:39 PM   #14
When acceleration in a auto when for Fe is it the best rpm to get to before it shifts
Old 12-13-2006, 12:48 PM   #15
I generally accelerate with as much throttle as possible up to ~3k rpm, then back off the pedal so it shifts to the next gear, rinse and repeat until you get to the speed you want to go. When accelerating brisk is better, and when cruising slower is better, as long as the car stays in it's top gear.
Old 12-13-2006, 12:56 PM   #16
Thanks a lot for, not only am I trying to improve my own gas mileage but I am also doing this topic for a presentation for a class. (I am in high school and it will help a lot if I try to show them that not only is it dangerous but it is very pricy to speed.) All your info helps a ton.
Old 02-21-2007, 01:22 PM   #17
Send a message via ICQ to occupant Send a message via AIM to occupant Send a message via Yahoo to occupant
The Honda Grade Logic controls make it tough to "coax" the transmission into shifting. I remember test driving two used Accords back in 1995. One was a 1991 5-speed LX, the other was a 1990 automatic DX, both sedans, both around 70-80K miles. The 5-speed was a joy to drive. The automatic always felt like it was holding each gear too long, and I could not let off the gas and make it shift, especially when going up or down any kind of incline. Engine braking is nice but I'd rather have the car GAIN speed when coasting downhill. If I had a Honda or other car with this kind of automatic transmission, you bet I would be putting it in Neutral all too often.
occupant is offline   Reply With Quote
Old 02-21-2007, 03:09 PM   #18
Sorry that I'm responding to late, but I was out of town when this discussion was active and didn't find it until now. I've been experimenting with the Accord DX for a while. I found that the best way to make it shift is on its own. When you let off of the gas then go back on, it's engine braking, then you're getting the engine back to speed. This wastes fuel. The best way that I've found with my Accord is to just accelerate very slowly. It will shift from 1 to 2 to 3 at around 2100 rpms, then at around 2300-2400 for 4th gear. Also, if it's safe to keep the speed above 52 in the country, do so because this is about when the torque converter kicks in. At 55 mph on the highway, you should be seeing much higher numbers than 28. Be certain that you're holding a constant speed. If it drifts off, get back to 55 slowly, not by letting your foot off of the gas or by stomping on the gas.
If you're in a hilly area, I can't help you much on hypermiling techniques because I live in South Florida where everything is flat. Also (and I know that I'm one of the only people on this forum who believes this), if you add about 2.5 oz of acetone to your gas tank with every 10 gallons of gas, you should see an improvement. I think that this makes a big difference in older high mileage cars because of how much gunk accumulates in the fuel system over time. I think that the acetone gets much of this out.
Old 02-22-2007, 04:05 AM   #19
This very similar as to how I try to manage the 'Tegs Auto when it's warmed-up; however, on Cold Starts, it won't shift below 2500 up to 3rd gear -- sometimes I have to give it a quick punch up to 2750 (make sure that when you lift the gas it stays above 2500) and it'll shift and use the higher gear. Do either of you have the same problem? (Maybe not so much in Florida I guess )
Old 02-22-2007, 06:23 AM   #20
I don't. The auto choke is minimal and only lasts about 3/4 of a mile most of the time on my car. When I went up to Athens a few weeks ago and was driving around in sub-freezing weather, I had all sorts of problems hypermiling, but for the most part, I don't need to worry too much about warm up times.
Problems with odometer MPG (Incorrect calculations) skymera Fuelly Web Support and Community News 4 11-26-2012 10:51 PM
Please add country filter raysky Fuelly Web Support and Community News 1 10-17-2012 01:20 AM
Why mpg testing is difficult and variable... ZugyNA Experiments, Modifications and DIY 22 07-26-2006 11:40 AM
Really interesting read... Compaq888 General Fuel Topics 0 02-07-2006 03:59 AM
What does a coil do? Matt Timion General Maintenance and Repair 5 11-28-2005 07:56 AM
