Tranny fluid flush for FE? - Page 3 - Fuelly Forums
Old 09-24-2009, 08:34 AM   #21
Arrow
If the factory is recommending a 100K mile service schedule, they may be putting in synthetic ATF. If you replace synthetic with conventional your mileage may go down.
Old 09-25-2009, 11:30 AM   #22
I would be replacing with synthetic.
Brontegirl is offline   Reply With Quote
Old 07-07-2010, 09:44 AM   #23
Id be careful what you put in honda transmissions.The factory reccomends honda genuine transmission fluid. The 6th gen accords were known for their tranny problems (98-02) so im tryin to stick with that.
RedAccord02 is offline   Reply With Quote
Old 07-24-2010, 03:04 PM   #24
please do not flush via vacuum(like shops try to sell)...http://www.buzzle.com/articles/trans...-problems.html
apparently particles can make their way to the valve body and cause issues.
Old 07-24-2010, 05:44 PM   #25
add|ct's Avatar
That's what I've heard of too from a couple older mechanics, that no longer do work for hire.
'92 Civic VX, Canadian model
Old 07-24-2010, 09:48 PM   #26
add|ct's Avatar
Is there a way to change all of your ATF, getting it out of the torque converter, without doing an actual flush?
I've heard about dropping the cooling line and having another tube re-route fluid as you pour more in. Doing this, though, after you've done the standard "fluid/filter" change. After that, then pour in new ATF while having the car in "D"(@ operating temp?), but park break applied and wheels blocked. Once the routing line shows the clean fluid stop pouring, attach line, then re-check levels since the tranny will be hot and hopefully you're on a level surface.
Is there a better way than that?
Old 07-25-2010, 04:04 AM   #27
That is still considered a flush, and it is the recommended style of flush. You don't pour in the ATF, you dip the other end of the line in it and let it get sucked in. The transmission's oil pump does all the work of completely replacing all of the ATF.
The only way I can think of to replace all the fluid without a flush is to take the transmission off the car and drain each piece by hand.
Old 07-25-2010, 06:03 AM   #28
add|ct's Avatar
Oh, I see what you're saying. I may try that. Hopefully I don't have to go through a ton of quarts before I can just top it off again.
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 01:49 PM
Recent change to mobile site? iSpyder Fuelly Web Support and Community News 1 06-30-2011 03:10 AM
vw recalls 800,000 cars budomove General Maintenance and Repair 22 08-01-2008 03:27 PM
Auto to Manual Reverse Light Question SVOboy General Fuel Topics 9 03-15-2007 10:28 PM
vx 5 wire o2 sensors on eBay!!! budomove For Sale 3 12-19-2006 07:41 AM
