Toyota Avalon Engine Off Coasting - Fuelly Forums
Old 09-17-2013, 09:48 PM   #1
GasSavers_HyperMPG's Avatar
How to Tow a Toyota Avalon Behind an RV | eHow
This article claims that Avalons older than 2008 can be flat towed if a transmission lube pump is installed.
For short periods, would I be able to engine off coast without damage, without installing the lube pump?
HyperMPG.net
GasSavers_HyperMPG is offline   Reply With Quote
Old 09-18-2013, 04:56 AM   #2
Based on past experience I would not bother with information found on ehow.com.
That said, sure, if you install the appropriate pump you can EOC almost any automatic. I haven't seen any serious technical discussions of short EOC runs with an automatic that is not equipped for that. I suspect that it would be fine but I really, really can't recommend it. If it's not fine, that's an awfully expensive repair.
Old 09-25-2013, 05:45 AM   #3
I've done it with a Ranger, but it was only on the down hill of some steep slopes. The EOC was maybe 2 miles out of a 60 mile commute. There was no problems when I had it, or any for my father when he had it for 60k miles. IIRC, I did drop the pan and change filter at least once.
I've tried it with our Sable. It has a gate between D and N though. So, nearly all the engine off I've done with it is at stops.
Like THC, I don't recommend it. Unless, the cost of a new transmission or repair isn't a big deal.
Old 10-29-2013, 07:03 AM   #4
I've been EOC for a while, both before my post and after, and I haven't noticed anything. Fluid looks clean, no burning. I do it at least twice in a 20 mile commute for a mile or two both times. I do try to rev match now. I think the most damage to transmission is actually shifting back into gear, though it does it fairly well.
HyperMPG.net
To draft or slow down? racertim Hypermiling 208 01-23-2009 06:27 AM
Appliance experts: What should I do with my fridge? theclencher General Discussion (Off-Topic) 28 10-30-2007 08:34 AM
Car trouble woes Fourthbean General Maintenance and Repair 10 07-30-2007 04:54 AM
Hydrogen Geo Metro onegammyleg General Fuel Topics 11 10-09-2006 04:02 AM
