Ride feels bumpy during braking - Fuelly Forums
Old 08-23-2009, 02:53 PM   #1
Question Ride feels bumpy during braking
This is in Bessie, my 2002 GMC Sierra 4x4 with 4 wheel disc brakes and 184,000 miles.
When braking, I get a minor bumpy feeling. I've never felt it before. I don't feel it in the brake pedal, I feel it in the seat. It's like I'm running over perfectly spaced bumps in the road, or like there's something stuck to my tire. It only happens while braking. A faint bump noise accompanies the feel.
It is not ABS engaging; I'm intimately familiar with my truck's ABS and that's not it. It does not feel like warped rotors; it's very well defined, on-off-on instead of fading in and out (hence "bumpy" not "lumpy").
I looked at my pads and rotors, they look good. There's no flat spots on the tires (and I'd expect that to feel the same whether braking or not).
Old 08-23-2009, 03:00 PM   #2
Maybe there's a stiff spot on a shock or strut, due to rust or something, bounce on it hard, see if it seems catchy. Would show up due to weight transfer.
Old 08-23-2009, 03:02 PM   #3
I forgot to mention, it's matched to speed, as if it's happening once per revolution...but I'll still have to check the suspension as you said.
Old 08-23-2009, 06:25 PM   #4
Did you check the insides of the tires for bulges?
Old 08-23-2009, 06:44 PM   #5
No, and I forgot to check the inside brake pads too.
Old 08-23-2009, 07:15 PM   #6
I would take a closer look at the rotors and shocks. How many miles do you have on the shocks?
Old 08-23-2009, 09:17 PM   #7
Another thing, tie rod ends, Wile-Es had been a smidgin loose, had new ones in hand, felt it vibrating today, gotta get 'em in real soon now.
Old 08-24-2009, 03:35 AM   #8
184,000
Old 08-24-2009, 04:57 AM   #9
I'd replace the shocks first. They're way overdue anyway. Large vehicles usually ride nice, even with bad shocks - so you may not experience a bad ride. Even my Buick will give a cloud-like ride with bad shocks. Oh, and because they've been in there so long, go ahead and go to Sears and get the lifetime shocks + installation. I bought that on my Buick, at the time installation + lifetime warranty was only an extra $9/shock. Well worth it. I've gotten several sets of free shocks over the years, and if the nuts holding them are seized (which is likely if you have over 180,000 miles on them) its worth it to not have to climb under there.
Old 08-24-2009, 06:25 AM   #10
Actually, my ride is significantly stiffer than it used to be. I attributed that to general wear on all the suspension, and specifically to tired springs, but maybe it's shocks.
If that's the case I'll just continue to defer that bit of maintenance. The symptom doesn't bother me except that I fear it could be a sign of something that will become more expensive to fix if I ignore it.
Lowering a car for more MPG MydnytRydr General Fuel Topics 7 05-03-2011 12:32 AM
--Will A Block Heater Do Anything For 5 Minutes?--- trautotuning General Fuel Topics 16 07-05-2008 07:58 PM
A Thank you GasSavers_Russ Introduce Yourself - New member Welcome 0 06-17-2008 08:25 PM
New to the forum..92 Protege DX jj94auto General Fuel Topics 3 04-24-2007 11:31 AM
Lighter Flywheel for Manual Transmission? cfg83 General Maintenance and Repair 24 12-21-2006 11:55 PM
