Please help Buick rpm's increase while parked/neutral - Fuelly Forums
Old 04-05-2009, 01:41 PM   #1
My Buick has started to accelerate uphill, the rpm's increase while idle, parked, neutral, coasting. It had a little difficulty starting a while back but starts fine now. I have no clue what's going on. Any help is appreciated. I don't drive the car much but I like to know that it will start when I need it.
Monkey Prey is offline   Reply With Quote
Old 04-05-2009, 02:29 PM   #2
What year, model, engine, and transmission?
I had similar problems with my 1987 Cadillac Deville, 4.1l V8 "HT4100", 4 speed automatic, TBI. I never did find out what was wrong.
Old 04-05-2009, 03:15 PM   #3
1990 Buick Century, automatic transmission, I stopped by autozone to get directions and they mentioned either an air leak, injector problem, or idler setting being off...
Old 04-05-2009, 04:55 PM   #4
I don't know anything about the way the Buick is set up. My '88 Escort has had that problem in the past and it was the idle speed control motor. That's one possible problem or an idle air control valve or a vacuum leak. I also had to replace the ECU in my '88 once because it would suddenly raise the idle a couple thousand RPM's.
Hipermiler
#47 on my way to #1
Old 04-05-2009, 06:14 PM   #5
I'm not really sure if that would be the problem. The difficulty it had starting. seems like it might be some other problem than the idle motor.
Old 04-05-2009, 06:35 PM   #6
I would look for a vacuum leak. Get a can of old fashioned carb cleaner. While the engine is idling spray down the vacuum lines. If the idle drops, or the car stalls when a particular part or hose is sprayed you have a vacuum leak there.
Old 04-05-2009, 07:14 PM   #7
Thanks for the tip, I was told to check for a leak but I couldn't hear one. I'll see if I can find the leak and post the outcome.
Old 04-06-2009, 08:54 AM   #8
Site Team
Extra air is getting in the motor somehow. Stuck throttle (cable, linkage, throttle blade), IAC motor, vacuum leak, etc.
-BC
Old 04-06-2009, 11:14 AM   #9
JanGeo's Avatar
The engine speed may increase not decrease when the flamable liquid is sprayed on the air leak as it would be adding fuel to the engine. A small spray of water could also be used as it is safer than a flamable liquid. Always good to check the gas pedal, its linkage and carpet around it too.
Old 04-06-2009, 11:59 AM   #10
I've heard both carb cleaner and starting fluid being used to test for vacuum leaks. I think carb cleaner is far safer... Its always worked for me.
Shift points changed? GasSavers_veloman Transmissions and Running Gear 12 11-17-2008 10:56 AM
Chart suggestions jeadly Fuelly Web Support and Community News 0 08-08-2008 02:46 AM
Memorial Day... GasSavers_JoeBob General Discussion (Off-Topic) 1 05-26-2008 03:54 AM
Thinking about CNG rh77 General Fuel Topics 15 06-03-2007 12:15 AM
Getting a 78MPG Diesel into the USA Davo53209 Diesels 19 05-24-2007 06:46 PM
