obd1 ecu w/ obd0 auto trany - Page 2 - Fuelly Forums
Old 05-13-2006, 10:05 PM   #11
GasSavers_Diemaster's Avatar
heres what i've found out.
obd1 (color) -> obd0
B7----(grn)------B7 P/N in
B4---(grn/blk)---B11 D4 in
B3---(grn/blu)---(add) D3 in
A19--(yel)-------A8 TC lockup (i hope your right svoboy.)
A17--(grn/blk)---DONT USE see up svoboy.
D18--(wht/red)---A10/mpfi/ps9 / B12/dpfi (interlock cntl)
as soon as helga is better and not beeing so *****iy on her period i will test the above.
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 05-14-2006, 08:19 AM   #12
The auto ecu will just give
The auto ecu will just give you a code since you're not using the partial lock-up and it'll be angry.
You should just wire a19 to 12v and be done with it on a manual ecu. You can ground out the park switch inhibitor thing so you can shift around without pushing in the lock.
More filters for graphs TnS Fuelly Web Support and Community News 3 02-12-2011 02:37 AM
initial fill up knhobson Fuelly Web Support and Community News 5 02-02-2010 05:13 AM
Me and my Del Sol Flatland2D Introduce Yourself - New member Welcome 5 09-19-2005 11:30 AM
