o2 sensor brand durability? - Fuelly Forums
Old 05-03-2006, 06:25 PM   #1
Anyone have an opinion of who's best out of Bosch, NGK or Denso?
Personally, I've only been able to find bosch locally so thats what I pick up but I haven't had a bosch o2 last longer than it should last...one was replaced at 22k and the other 24k! They should last 30k, what a ripoff ya know?
sparkplug.com has them cheap as the local stuff.
-unknown
Old 05-03-2006, 06:34 PM   #2
NGK/Denso should be the
NGK/Denso should be the same/best. My stock one has worked fine for 120k, Bosch bones.
Old 05-03-2006, 06:36 PM   #3
Compaq888's Avatar
NGK all the way!! Bosch
NGK all the way!!
Bosch blows. I'm in the process of replacing all the bosch crap with NGK. I'll probably replace my oxygen sensors at 100k
Old 05-03-2006, 06:50 PM   #4
SVO, how many wire is yours?
-unknown
Old 05-03-2006, 07:34 PM   #5
Only a 1 wire. On a side
Only a 1 wire. On a side note, I pulled one off a free engine that'd been sitting outside and it's still running strong,
Old 05-03-2006, 07:39 PM   #6
Compaq888's Avatar
Re: Only a 1 wire. On a side
more free stuff???
ROFLMFAO
Old 05-03-2006, 07:43 PM   #7
Nah, this is all part of the
Nah, this is all part of the free bundle of crap I got including dan's transmission.
Old 05-03-2006, 08:32 PM   #8
svo
in my experience o2 sensors rarely cease to operate. However, its a question of how well they work as they age. I wonder if a mechanic with a scanner would say your o2 is "healthy" or not?
As the sensor ages it will get whats called sluggish, it will not necessarily ever break or fail.
Sluggish means that the voltage coming from the o2 will greatly transition only once per second. This lean to rich fluctuation should happen twice per second or more on the newer cars(o2's) to be called "working" and "healthy"
The fluctuations are simply lean/rich representations as voltages. There are "bench tests" that can check an o2 but I really don't think they are worthwhile and accurate. A running test engine and scanner will show you exactly whats going on.
-unknown
Old 05-03-2006, 08:37 PM   #9
I gave it to someone who had
I gave it to someone who had a lazy o2 sensor, and it solved his hesitation issues, so I'm confident it's working well.
Old 05-03-2006, 08:47 PM   #10
coolio, will look into ngk/denso brands
-unknown
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Can fuel descriptions associate with mileage at *next* fuel-up? anthill Fuelly Web Support and Community News 2 01-30-2011 10:32 AM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
