o2 sensor brand durability? - Page 2 - Fuelly Forums
Old 05-04-2006, 06:27 AM   #11
Moderator
GasSavers_DaX's Avatar
For 4 or 1 wire units, I buy
For 4 or 1 wire units, I buy only NTK. For 5-wire units...BOSCH!
Old 05-04-2006, 10:12 PM   #12
GasSavers_Diemaster's Avatar
Re: svo
Originally Posted by n0rt0npr0
However, its a question of how well they work as they age. I wonder if a mechanic with a scanner would say your o2 is "healthy" or not?
as a macanic i can say that when a o2 gets "lazy" it dosent switch from rich to lean and vice versa fast enough. when they smog your car, they hook up a DSO or digital storage ocolascope (o-sill-a-scope) and can see how fast it switches. obd0 / 1 is 100ms and obd2 is 75ms.
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 05-04-2006, 10:14 PM   #13
on a side note do u recomend
on a side note do u recomend the same as honda uses (ngk?) like this one:
http://rywire.com/store/product_info.php?cPath=36&products_id=60&osCsid=af 6781d38053eef6a3b220545e882ea2 or will any (boush) work w/ a obd1 swap?
I ♥ my EM2
Old 05-05-2006, 01:54 PM   #14
95metro's Avatar
OEM the best?
When I replaced the O2 sensor in my old Dodge Spirit I cheaped out and went with a Bosch. It crapped out after 40,000 km...the OEM one had lasted around 260,000 km.
I've heard this is relatively common. OEM components just seem to last longer than aftermarket in my experience (I had the same issue with some Monroe struts compared to the OEM struts from Dodge - OEMs lasted 3x the distance).
95metro is offline   Reply With Quote
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Can fuel descriptions associate with mileage at *next* fuel-up? anthill Fuelly Web Support and Community News 2 01-30-2011 10:32 AM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
