I'm not saying you can not do it, but I am saying for transmission longevity I recommend leave it in D always, also I am saying if you shift it you do so at your own risk.
Here's the thing, even if the chances of breaking it are but 1 in a million...
Who has to pay for it if (or when) it breaks?
You think one of these hot shot shift pros here are going to spring for it?
Personally I think you have to pay for it, if it breaks.
Yes, it can go flawlessly hundreds if not thousands of times.
All it takes is one time, one mistake, one bad luck moment.
What slowed me down is the price of a rebuild, and the fact most transmission specialists say the same thing: You want fail-safe operation then leave it in D.
That having been said, I do coast in N.
Hahaha but I have to say these things, I don't want nobody crying the blues if their tranny craps out for any reason.
Originally Posted by Bruce
Don't push the shift lock button (or pull forward on a column shift) when shifting between Neutral and Drive. This will prevent accidental shifts into Park, Reverse or the Low range. Just push the shifter back and forth.
Better yet, spend some time playing with the shift lock button and lever positions while the car is parked with the engine off to understand how it works. You should only need to depress the shift lock button to shift out of Park or to shift into Reverse, Park or the Low gears.
Until it malfunctions, or I shift so fast the detent mechanism fails to engage properly thus overriding the stop between N and R. Sometimes they break, sometimes they don't work like they should, my oldest car I can shift to-from any gear any time, doesn't matter when, how, or where.
Also column shifters work different from a floor shifter, but either one...
