Need help Brake Bleeding problem - Fuelly Forums
Old 03-31-2009, 10:30 AM   #10
If the pedal is soft then you have either some travel in the pads and shoes (rear) or air trapped someplace. Easy way to flush the front lines is to remove the pads and allow the piston to come out more than usual then press them back in thus flushing the fluid and air back up to the master cylinder. When bleeding you can also just crack the bleaders a little and press hard on the pedal to force the air out of the wheel cylinders. It is also a good idea to pump the master cylinder with short strokes from the full up position (quick up and then back down quickly) so you keep fluid moving through the lines and don't let it flow back up as it may in a longer stroke. You can also set the hand brake to keep the rear shoes from moving while you bleed them depending upon how they operate.
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 12:49 PM
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 12:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 01:50 PM
Small high pressure water pump? landspeed General Fuel Topics 8 06-03-2008 05:05 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
