Need help Brake Bleeding problem - Fuelly Forums
Old 03-21-2009, 04:54 PM   #13
Member
Ratman667's Avatar
And as long as the master cyl res is higher than the wheel cyl, it doesn't matter one bit whether there's a vertical run in the line or not.
this may be true for removing the old fluid. but if there is an air bubble in that vertical part of line, it will not be forced out by a trickle.
Ratman667 is offline   Reply With Quote
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 12:49 PM
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 12:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 01:50 PM
Small high pressure water pump? landspeed General Fuel Topics 8 06-03-2008 05:05 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
