Loud groaning from front end - Page 2 - Fuelly Forums
Old 12-21-2010, 08:04 AM   #11
kamesama980's Avatar
Re: Loud groaning from front end
Originally Posted by trollbait View Post
Yep, it was a bearing. Just one, but I had to have it off to tell which one it was. An HHR site had a clear write up on how to change them. Didn't need any special tools. The only hassle was one of the caliper pins was corroded and seized up. That's more because I had to run out and pay retail for the parts.
So, two new bearings and new pins on one brake. The bad pin didn't have the decency to be on the first wheel worked on, but the other side can wait til spring.
For future note, when checking the spin of a drive wheel, should both wheel be off the ground?
Doesn't really matter in the grand scheme if the trans is in neutral. if it's in park, obviously it won't spin at all with only 1 wheel up. on a lift I've tried it in park and in neutral and there's about as much differential noise/vibration either way.
-Russell
Adding service costs to total cost statistics. Idontpayroadtax Fuelly Web Support and Community News 6 06-05-2014 12:02 AM
A URL parameter to expand notes please. m1sterc33 Fuelly Web Support and Community News 2 04-17-2012 08:47 AM
air intake thoughts GasSavers_ccrider General Fuel Topics 8 11-07-2009 08:05 PM
Monitoring VX Engine/Sensors/ECU djenyc General Maintenance and Repair 3 11-22-2008 05:46 AM
Vast Oil Pool Tapped in Gulf of Mexico ketel0ne Automotive News, Articles and Products 5 09-08-2006 06:30 AM
