Lifter ticking? - Page 2 - Fuelly Forums
Old 10-12-2012, 09:29 PM   #11
That's the way I've always done it.
Jay2TheRescue is online now   Reply With Quote
Old 10-13-2012, 07:46 PM   #12
GasSavers_Erik's Avatar
When you set the distributor, make sure you are at TDC between the compression stroke and the power stroke (it would be also possible to set it to fire at TDC between exhaust and intake strokes).
Old 10-14-2012, 04:16 AM   #13
That part we already did. We made sure the truck was at TDC on the compression stroke by locating the mark on the crank housing, behind the pulley, and lining it up with the TCD line when the #6 valves were both slightly open. (the passenger side valve cover is easier to remove than the driver's side). The truck didn't fire up right away, so Greg turned the distributor in between crank attempts. It finally firied right up. I think he just turned the cap in relation to the distributor body. I can look at where he has it lined up later; I was dark outside, and I had previously marked its location relative tot the intake manifold. I wonder if just a few degrees made the difference.
In any case... It's ALIVE!!!! and not leaking.
Family Carpooling BumblingB General Discussion (Off-Topic) 2 06-07-2008 01:37 PM
