Is all ATF +4 synthetic? - Fuelly Forums
Old 07-25-2010, 11:49 AM   #1
add|ct's Avatar
Hey guys. This was inspired by bowtieguy's thread here: http://www.gassavers.org/showthread.php?t=12182
Instead of his question, I have a few minor concerns regarding the use of Valvoline's ATF +4 in my '99 Stratus.
http://www.valvoline.com/products/co...ssion-fluid/32
The Stratus has a 41TE transmission and probably came with ATF +3, I believe, but not sure. That is, unless all Stratus' models by that year were incorporating ATF +4, but I don't know what year that type of ATF came out?
I may have been the only person to service the transmission on this car(which was a filter change/fluid top off with "ATF+4", a store brand version at around 95k), so it at the very least has a marginal amount 'newer' ATF fluid and currently has over 100k on the majority of the ATF currently in the system.
I was thinking of using the Valvoline product. Amongst its claims is: Officially licensed and Chrysler approved.
Specs:
http://www.valvoline.com/pdf/Valvoline_ATFplus4.pdf
Thoughts of doing a 'mini' flush; simply allowing the cooler line to drain and add new fluid as needed until all is new fluid/have gone through the total number of Quarts called for, and that way replace all of the fluid myself for about $80(fluid, filter, gasket)?
I'm having some symptoms of RPM drop entering 4th gear and I'm suspecting the torque converter.
ADDED:
Found this http://www.centerforqa.com/
'92 Civic VX, Canadian model
Can we disable hashtags? Helltime Fuelly Web Support and Community News 3 06-23-2013 05:48 AM
Basic Stats darkangel7 Fuelly Web Support and Community News 2 11-21-2010 04:29 PM
Newbie Here Barnone Introduce Yourself - New member Welcome 0 03-09-2009 09:22 AM
Hybrids may pose greater risk for pedestrians! rgathright Automotive News, Articles and Products 6 05-14-2008 06:18 PM
LPG conversion SVOboy General Fuel Topics 4 03-24-2007 09:33 PM
