I have discovered injector off coasting! - Fuelly Forums
Old 05-15-2006, 06:48 AM   #1
Just like I said, if my lock-up solenoid is in full lockup then I can take the foot off the pedal in gear and the injectors will shut off, how fantastic!
This may suck for those of you with partial lock-up, but it should be easy enough to figure out when you're in full lock-up.
Old 05-15-2006, 06:57 AM   #2
all hail superMID and the
all hail superMID and the knowledge it spawns.
Old 05-15-2006, 07:00 AM   #3
Yes, if only I could stick
Yes, if only I could stick this electronic vss in my tranny and get the instant going.
Old 05-15-2006, 08:20 AM   #4
basjoos's Avatar
You can also tell when your
You can also tell when your ignition is shutting off by tuning to an unused AM frequency on your radio. With the volume turned up, you can hear a light sputtering noise generated by the ignition system that changes with RPM. This noise drops out entirely as you head down a hill in gear with your foot off the accelerator. At least this detection method works on my 02 Honda Odyssey and my 92 Civic.
aerocivic.com
Old 05-15-2006, 08:22 AM   #5
Haha, that's rediculously
Haha, that's rediculously clever. I'm glad I have the superMID cuz I wouldn't be able to put up with that ****.
Old 05-15-2006, 09:07 AM   #6
mtbiker278's Avatar
I'm gonna have to try that
I'm going to have to try that.
mtbiker278 is offline   Reply With Quote
Old 05-15-2006, 09:56 AM   #7
Compaq888's Avatar
Re: You can also tell when your
That kind of doesn't make sense. Why would the ignition shut off unless you're saying that fuel injection shuts off when you have your foot off the gas. Is that what you're saying????
Old 05-15-2006, 09:58 AM   #8
Compaq888's Avatar
Re: I have discovered injector off coasting!
Please explain partial lock up and full lock up. Also what are your rpm when your injectors shut off?
Old 05-15-2006, 10:08 AM   #9
lockup
Hey do the plugs keep firing when the injectors don't inject any fuel??
Old 05-15-2006, 10:21 AM   #10
Moderator
GasSavers_DaX's Avatar
Re: lockup
Honda ECU's simply cut the ground to the injectors on 0% throttle decel. The ignition is still firing inside the dry cylinders though.
Honda also uses a fuel cut instead of an ignition cut for the rev limiter.
Two stroke oil in diesel Eybrows General Fuel Topics 16 01-27-2013 08:20 PM
Fuelly Moving to New Servers pb Fuelly Web Support and Community News 4 11-30-2011 09:31 PM
long time MPG nut JanGeo Introduce Yourself - New member Welcome 8 01-23-2006 02:33 PM
Parking Brakes and Fuel Economy? Matt Timion Automotive News, Articles and Products 0 10-03-2005 01:23 PM
