Fuel Pump ('93 Civic) - Fuelly Forums
Old 07-11-2009, 10:56 AM   #1
Finished the clutch. Thanks to all who commented and left many great tips. I ended up LIFTING the transmission and putting it on! Nothing subtle. All those visits to the gym finally paid off.
I have an odd problem. When the car (1993 Civic CX) sits with its nose even slightly pointed uphill, it won't start. The second the nose points even the slightest bit downhill, it fires right up. I'd like to avoid dealing with the fuel pump, of course. But, after the clutch, everything should be... downhill, right?
Any thoughts?
tucsonron is offline   Reply With Quote
Old 07-11-2009, 02:41 PM   #2
GasSavers_bobski's Avatar
In the no-start condition, can you hear the fuel pump prime for 2 seconds when you switch the ignition on?
You remembered to reconnect the engine wiring harness ground to the thermostat housing, right?
Old 07-12-2009, 03:40 PM   #3
GasSavers_TomO's Avatar
could be a main relay issue, but if it ends up being the furl pump, they're easy to get to on the 5th generation Civics.
Honda Civic VX Info/Links
Old 07-14-2009, 02:44 AM   #4
It's just such a weird, intermittent problem. I keep forgetting about it. Why would the car only fail to start when sitting nose up? If I am sitting at a light with the car running nose up, it doesn't stall. Guess I'll replace it, I have to take the whole rear interior out anyway (badly run speaker lines).
Old 07-14-2009, 03:43 AM   #5
Site Team
I'd suggest you start the car and then go around and start jiggling wires. I think you'll find a loose connection or something.
(Just a guess)
-Bob C.
94 GS-R with VX swap onefastcar Introduce Yourself - New member Welcome 9 07-09-2008 04:12 PM
? for dmm user's, monitoring lean burn rlprlp1 General Maintenance and Repair 4 12-17-2007 11:16 AM
hi new member here and ive got some sick ideas! csrmel Introduce Yourself - New member Welcome 6 10-18-2007 02:23 PM
Hypermiling Auto Trans w/ Tach brucepick Transmissions and Running Gear 4 04-12-2007 12:32 PM
Cardboard box + duct tape = LxMike Aerodynamics 18 11-18-2006 11:53 AM
