Drove my new '92 VX home today! - Page 2 - Fuelly Forums
Old 12-09-2012, 11:56 AM   #11
1993CivicVX's Avatar
Good news! It needed a tune up!! Purrs like a kitten. Also, since this car has a working odometer, I'll be doing a gas log. Even with herky-jerky driving (I really went flat out for parts of the tank for diagnostic purposes) I still returned 51mpg for the first tank in cold weather and on a motor that desperately needed a tune up. Not bad for a car with 243K!
three stripes the charm!
Old 01-01-2013, 03:15 PM   #12
The temp has gone up on multiple occasions now. The highest was just below the white line that is right below the red line going up a steep winding hill. The radiator fan did not come on. As far as I know, the radiator fan never comes on. However, the guy who I bought a spare set of wheels from said he tested the radiator fan and it worked. So not sure why it's not coming on?
Old 01-01-2013, 06:06 PM   #13
GasSavers_WD40's Avatar
You might need to bleed air out of the bleed screw at the top rad hose, if there is an air lock it causes issues with water flow.
GasSavers_WD40 is offline   Reply With Quote
Old 01-01-2013, 08:20 PM   #14
If its not some air The only other thing is the coolant temp switch for the fan not sure which one it is. I don't think I've herd my fan run on either of my civics. The needles never seem to go up past half. I have herd that when the do run it's at most for like 45 seconds.
Rusty94cx is offline   Reply With Quote
Old 01-01-2013, 09:03 PM   #15
45 seconds is all it would probably take to bring the temp down as running the incabin heat almost is always enough to control the temp (except going up the hollywood hills yesterday). The car is also pretty laden the last few days. At minimum it's been 3 people and their stuff. Thanks guys, I will look into those things.
Old 01-04-2013, 11:04 AM   #16
The fan came on when I was teaching my friend how to drive stick. Strange thing was, the fan came on when the Engine was off. The car hadn't been driven very much and the temperature gage had not risen. The engine had been started and stopped a few times. I am not sure if the fan continued to run after the engine was started. Another odd thing about this: when my friend had turned the key to start the car the fan turned off at the start position (probably because accessories get turned off to save battery when the engine is being started), But the engine didn't actually start. Nothing happened; but this was probably only due to the alarm system preventing the car from starting. The car did start normally shortly after but I don't remember hearing the fan continue running; I wasn't really listening though because I wanted to finish the lesson.
Old 01-04-2013, 01:26 PM   #17
Be careful don't let him burn the clutch up. Hmmm I'm wondering if the alarm is a possible problem or the ignition switch. You need to try with the car running jump that connector. The circuit is in tact with ignition off and yes the fan should run then if hot. And yes it should turn off while cranking. I hate car alarms. They can throw alot of wrenches into the mix.
Hypermiling in a Diesel 8$PG Diesels 15 06-18-2014 06:55 AM
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
Tire Talk from Car Talk shatto General Fuel Topics 5 05-23-2012 09:44 AM
The Eclipse at Shatto's Home May 20, 2012 shatto General Discussion (Off-Topic) 0 05-20-2012 11:44 PM
Fire Truck shatto General Discussion (Off-Topic) 3 02-24-2012 10:27 AM
