Does a bearing poop in the woods? - Page 2 - Fuelly Forums
Old 10-12-2010, 06:36 AM   #11
kamesama980's Avatar
Re: Does a bearing poop in the woods?
Originally Posted by ************* View Post
It turns out, the bearings are usually double ball bearing which totally sucks imo.. I'm going to try to find a way to see if I can get some tapered roller bearings for my civic in place of these ball bearings.. Totally disgraceful that they'd use ball bearings.
good luck with that. for the price of finding bearings and machining the hub/spindle to accept them you could replace the balls a couple times probably.
I just checked on parts listings on rockauto, the front bearing up till 2002 is a NON SEALED double row ball bearing that's pressed in. you can mess it up installing it but more likely, they haven't replaced the grease seal (many places do overlook this) and it isn't sealing anymore or the polished area it mates to is damaged causing even a new seal to not do it's job.
after 2002 it's a self sealed version of the same thing.
Could also be something like a bent hub (or wheel if you haven't rotated the tires) or damaged knuckle causing problems.
-Russell
Old 01-14-2011, 05:46 AM   #12
norurb's Avatar
I apologize if this is considered bringing back an "old" thread.
My '92 Infiniti G20 went thru a couple of front left wheel bearings in 2 months. Then I realized the hub needed to be changed ALONG with the new bearing. Our 3rd attempt was a success after changing both the hub and wheel bearing. I spent $40 for the ebay hub and $20 for the ebay wheel bearing.
norurb is offline   Reply With Quote
Window Proportions GasSavers_maximilian General Discussion (Off-Topic) 5 09-18-2009 03:42 AM
How to trick the EFI on newer cars... Nightwish Experiments, Modifications and DIY 4 05-30-2008 04:44 AM
vx 5 wire 02 Paulie D Wanted to Buy 0 12-17-2007 07:37 PM
VX Fuel System Cleaner Q GasSavers_James General Maintenance and Repair 5 06-18-2007 07:47 PM
New Scangauge ron22 Hypermiling 7 03-28-2007 06:01 AM
