D15Z1 (economy vtec) In to 88 Civic Transmission Question - Page 5 - Fuelly Forums
Old 08-27-2006, 09:00 PM   #41
Iono WTF that pictue is but it's wrong, I can take a picture of a transmission in my basement for you.
Anyway, none of the auto tranny mounts work, they're all slightly different. You can get the manual ones fairly cheaply though.
Old 08-27-2006, 09:02 PM   #42
where should i look for the transmission mounts?
8Civic8 is offline   Reply With Quote
Old 08-27-2006, 09:05 PM   #43
Junkyard/h-t. You can get them new from honda if you pay out the nose. Check with the person you buy the tranny from. If they went b/h/k series they'll have them for you.
Old 08-28-2006, 05:17 AM   #44
Moderator
GasSavers_DaX's Avatar
Here's where I got everything I needed for my conversion:
*HF transmission - a friend's back yard (try Honda-Tech or a local honda board...I have ImportAtlanta.com)
*Rebuild parts for HF tranny - www.hondaautomotiveparts.com
*Pedals - Junkyard
*Flywheel - I had one, try Honda-Tech or ImportAtlanta equivalent
*Clutch - eBay (less than $100)
*Shift Linkage - Junkyard
*ECU - Honda-Tech
*Mounts - Honda-Tech
*Clutch Cable - Autozone
Old 08-28-2006, 08:05 AM   #45
Would it be easier to conver to mpfi and obd2 if i had a harness from a mpfi crx? Or is it the same regardless?
Old 08-28-2006, 09:50 AM   #46
Matt Timion's Avatar
You want obd1, not obd2.
It's best to stick with your existing harness. Not only is it cheaper, but the MPFI wiring only takes like 30 minutes if you just follow the directions and know how to do a little wiring.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 08:48 AM
Distinction in 'garage' for cars we no longer own Smitty Fuelly Web Support and Community News 3 09-12-2008 07:50 AM
WTB: Scanguage 1 for $50. krousdb Wanted to Buy 9 10-31-2006 10:45 AM
Car stalls when idling and A/C is on Matt Timion General Maintenance and Repair 7 05-20-2006 04:32 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 01:52 AM
