Clunking from rear wheel - Fuelly Forums
Old 08-25-2012, 02:04 PM   #1
The title says it all. The HHR is approaching 117k miles, and the shocks are original. So that's my first guess. What else should I check?
The tires are new and are a little larger(225/55r16 to 205/60r16). The noise did start after their install, but it appears to only be coming from the passenger side.
Old 10-16-2012, 07:23 PM   #2
kamesama980's Avatar
Ever track it down?
Sway bar links are a good bet. Same for strut/shock mounts.
-Russell
Old 10-18-2012, 04:15 AM   #3
Sport/Truck's Avatar
Originally Posted by kamesama980 View Post
Ever track it down?
+1 on the swaybar. I had simular issue on my car and it was the dog-bone that connects the swaybar to the chassis.
Sport/Truck is offline   Reply With Quote
Old 10-18-2012, 08:24 AM   #4
Loose wheel lugs!!!!!!!! Next check the brakedrums and pull them off to check shoes.
Old 10-18-2012, 08:38 AM   #5
Way back in history I once bought a set of rims and had the tire shop install them. My car started rattling as if it had a load of aluminum extension ladders on a roof rack. Turned out that the way the wheels fit, with the lug nuts fully tightened, somehow allowed the drums to to slide along the studs and bang between the hub and wheel.
Old 10-18-2012, 11:08 AM   #6
Well, its all OEM, and spraying silicone lube on bushings and other rubber parts didn't help the isolate it. When I rotate the tires, I'll take another look, but it seems to have quieted down on its own.
I got used to it, or the mysterious front end noise of the HHR is drowning it out. That gets worse in the cold. It wasn't mentioned during the annual inspection, but I take it to a Chevy place and they know about the mysterious noises.
The gas filler is there, and the filler neck might loose. Same with the battery. It could have simply been something in the back storage area, and I accidently fixed the noise moving stuff around in the car.
Old 10-18-2012, 04:15 PM   #7
GR8MPGcrx's Avatar
Do you have drums in the rear?. I had a similar problem with "clunking" i guess you would say. I had replaced the rear shoes and drum on my civic. A few days later I began to hear this clunking, only after turns at low speeds, and only sometimes. I ended up taking the drum back apart, but to my surprise, it was full with sand. Enough sand to fill the small of your palm. Not sure how it got in-there, but cleaned it our with a air hose, checked for scoring, put it together, and it has not happened since.
GR8MPGcrx is offline   Reply With Quote
Old 10-18-2012, 05:21 PM   #8
How much sand? Could it have been stuck to the inside of the drum from the casting process?
Old 10-20-2012, 11:14 AM   #9
GR8MPGcrx's Avatar
Hmm, possible, but thinking about it, I do drive 2 mi on a dirt road every day, so maybe that's a possibility too. Just enough sand to fill the palm of your hand.
Old 10-20-2012, 12:16 PM   #10
when I had my windshield replaced they said I have a lot of dirt under the grill work below the glass and I don't live on dirt roads but I did drive on some last June and apparently it gets in there and doesn't wash out. I had it pouring out of my hub caps after that couple of miles of dirt road driving. that dirt can get in the darndest places.
iphone mobile broken RicksCafe Fuelly Web Support and Community News 2 01-22-2012 07:02 AM
Optimal shape of wheel deflectors - convex/concave? MetroMPG Aerodynamics 8 01-01-2008 09:29 AM
Engine idea: steady speed P&G with flywheel/capacitor storage GasSavers_Rotareneg General Fuel Topics 3 08-28-2007 07:58 AM
Hello GasSavers GasSavers_rGS Introduce Yourself - New member Welcome 1 06-10-2007 08:47 PM
omgwtf & FormulaTwo: I got yer car right here! theclencher General Discussion (Off-Topic) 5 02-03-2007 01:16 AM
