Civic Front Axle - Page 2 - Fuelly Forums
Old 07-16-2009, 07:01 PM   #11
Some diffs fall apart with no axles in, so you have to put a keeper in there to make sure nothing falls out of line if the car gets a knock. Basically a clean bit of broomhandle or something. However, if you pull one straight out, and put the new one stright in, you shouldn't really need to do that, only if you're expecting to do other stuff while the axle is out.
Old 07-16-2009, 08:06 PM   #12
GasSavers_bobski's Avatar
Originally Posted by Erik View Post
Maybe you could just put the spare tire on for the loosening step.
Maybe, though I've seen spares slip (spin) on the pavement when trying that, so maybe not. Just make sure you're pushing down on the extension bar, increasing traction.
Never heard of a Honda or Acura doing that. The worst I've heard is an axle getting stuck in the transmission due to a poorly machined aftermarket LSD or an overly loose/spring-y retaining clip.
Old 07-18-2009, 02:41 PM   #13
Member
Geonerd's Avatar
The only real difficulty I had (92 Accord, FWIW) was getting the @#$%$% axle nuts off. If you're using a breaker bar, get a 1" setup. A 3/4" bar can and will shear and break. (Trust me, I know! I wound up buying a compressor and gun - 5 seconds of buzz and and they were off!) If you know someone with an air gun, have them 'crack' the nut for you. You can then hand tighten with your breaker bar and drive home to do the work.
While you're in there, you might want to change the drive shaft seal(s). They're easy to pop out with a seal pulling tool. Pressing them in evenly is a bit trickier, but is also easy with the right equipment. Don't try to 'chase' it around with a small hammer - you need to press evenly, or it will just bind up. I found a short piece of electrical conduit fixture (essentially a short bit of pipe) at the hardware store that nicely fits over the metal outer ring of the seal. Light hammer taps seated the seal perfectly.
Geonerd is offline   Reply With Quote
Old 07-18-2009, 02:56 PM   #14
Yeah some of those OBX LSDs are meant to have slightly oval splined axle holes, so you need to clock the axle for best fit...
Old 07-18-2009, 04:21 PM   #15
I read that it was an issue of not machining a taper on the edge of the splines in each pinion. As it is supposed to do, the circlip on the axle would compress on the way in and pop open once fully inserted to keep the axle from slipping out. OBX mistakenly omitted the taper on the inside end of the splines so there was no way to re-compress the circlip and remove the axle.
Old 07-19-2009, 04:49 AM   #16
Yeah, that would probably more apply to hondas. The oval hole is what get's 'em stuck in non-circlip apps, when they're forced in, or not even sitting in very well but with the axles sprung against them, then as the diff gets hot and expands, they seat themselves rather solidly.
Old 07-21-2009, 10:17 AM   #17
DONE! I swapped the axle on Friday night. The only issues I ran into were:
1. The Haynes manual stated that you should remove the front stabilizer bar from the lower control arm. Unfortunately, you can't do this and re-use the ball joints, so I just removed the lower ball joint from the hub to the lower control arm. That did the trick so I could get the axle out.
2. When I tried to pull the axle out of the tranny, it first broke apart at the inner CV joint. Then, I had to pry the axle out of the tranny.
3. I still hate changing the transmission fluid on Hondas. The filler neck is a B!@#$ to get to, even with a fluid pump.
Thanks for your help, everybody!
Old 07-21-2009, 10:33 AM   #18
That's normal. The inner CV joint is constructed as a cylindrical cup with 3 grooves cut into it's interior wall. A ball bearing rides in each groove, with the center race of each bearing riding on a 3-pointed spider. The drive shaft runs through the center of the spider. That means if you pull on the shaft while the cup is still anchored to the transmission, the spider and bearings will pull out of the grooves. All you have to do is use an appropriate pry-tool to unseat the inner joint from the transmission (unseating the circlip really) before pulling on the shaft. Even the factory service manual says to do it that way, but gives dimensions for a pry tool... I assume to minimize the potential for damaging the oil seal.
A few years back, the auto parts stores around here started selling these tube/valve attachments that screw onto oil bottles. You take the cap off your trans fluid bottle, thread this thing on in it's place and close the valve. With the valve closed you can't spill fluid, so you can work the bottle in wherever it needs to be for the hose to reach the fill hole on the side of the trans. Once positioned, you open the valve and squeeze the bottle to pump fluid into the trans.
Old 07-21-2009, 11:02 AM   #19
GasSavers_Erik's Avatar
I second that suggestion- that's exactly what I use to fill my Honda tranny.
Old 07-22-2009, 05:12 AM   #20
I had one of those, too. The only problem is that when the bottle is nearly empty, it tends to siphon fluid back out of the tranny.
On the other hand, the fluid pump cannot get the last 1/4 quart of tranny fluid out of the container.
So what I did is attach the valve to the fluid bottle and held it upside down. I attached the other end of the valve to the pump. When the bottle was nearly empty, I poked a hole in the bottom for air so it wouldn't siphon the fluid back out of the tranny.
Arco gas - mileage poor jbum General Fuel Topics 9 07-07-2013 12:25 PM
? for dmm user's, monitoring lean burn rlprlp1 General Maintenance and Repair 4 12-17-2007 11:16 AM
super mid Hockey4mnhs General Fuel Topics 5 06-03-2007 01:57 PM
f/s 93 civic VX Olympia washington progsr For Sale 0 12-01-2006 02:12 AM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 08:40 PM
