bleeding of the transmissiom - Fuelly Forums
Old 03-04-2011, 10:46 AM   #1
Is there any body out there know anything about if auto transmission
Do you have to bleed the lines to the tx cooler if you get air in it?
GasSavers_gashog is offline   Reply With Quote
Old 03-04-2011, 10:48 AM   #2
Re: bleeding of the transmissiom
AFAIK there is no need to bleed it. Any bubbles should work themselves out quickly while running or within a few seconds after shutting down, when the entire system drains back into the pan.
Old 04-15-2011, 08:38 AM   #3
kamesama980's Avatar
^ I second that. I've done dozens of transmission fluid exchanges on cars at several jobs and I've never once had a problem. The cooler lines typically drain back into the pan so they seldom see more than a few PSI and lines and cooler can be cheaper.
-Russell
Some ridic article by some fool SVOboy Automotive News, Articles and Products 40 04-25-2010 08:04 AM
Better mileage going 65 than 60? Jonathan_ED3 General Fuel Topics 18 12-03-2008 07:46 AM
ok, i admit it... im a newbie argylesocks Introduce Yourself - New member Welcome 39 10-09-2006 09:07 PM
