BIG car - Page 2 - Fuelly Forums
Old 09-27-2007, 11:13 PM   #11
Team GasMisers5!
landspeed's Avatar
If the engine is coming out, how about increasing the compression ratio a little bit? I think that would give more fuel economy, and maybe even more power (if you can avoid knock at maximum load).
Hypomiler
Old 09-27-2007, 11:32 PM   #12
theclencher's Avatar
I applaud his decision to use a sedan to move the 5 big folks instead of the more usual "need" to get a Subdivision or Explosion.
I also understand that since this car practically fell in your lap, that's what you're going to use. Just to mention, though, if you come across a GM full-size fwd with the 3.8 (think Le Sabre, Bonneville, etc.) from the late '80's on, they should give an honest 30 mpg hwy properly driven, stock. For some reason that 3.8 is a decent fe package in those larger cars, equalling or besting the fuel efficiency of the same model with a smaller engine! I wonder how they would perform with a 5-speed stick and removal of all those power-robbing accessories?
IMHO, the four-valve head's main strength lies in high rpm applications, OR, if equipped with a variable valve control system of some sort, low and high rpm applications. Since it is unlikely you'll transplant a variable valve control system (and I don't know if it was ever offered on that engine series???) AND since low rpm operations are our fe friend, my instinct is to stay with the 2-valve head. You may want to research fe ratings for different versions of that engine in as consistant a drivetrain package as possible to see what is really going on out there.
If the 6 speed offers a taller OD than the 4 speed it MAY help. If cruise rpm is too high for best fe, higher rear end gears and/or taller tires could help too without being as big an effort or expense.
Even with these mods I have my doubts about getting 30. It's just such a tall order for a V8 especially in a full-size package. Seems the odds get much better with a 6 cyl.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 09-29-2007, 03:34 AM   #13
rearend
I didn't see mention of changing out the rear gears for lower cruising rpms yet.
sipnciv is offline   Reply With Quote
Old 09-29-2007, 03:55 AM   #14
Yep, it's there.
Old 09-29-2007, 04:15 AM   #15
s1120's Avatar
Well a gear swap may not work. Whats in there now? It is a big car, and those Mod motors like some rev's so if you go to too tall a ratio, you could drop the motor out of its power band, and make the millage worse.
Paul B
s1120 is offline   Reply With Quote
Old 09-29-2007, 12:31 PM   #16
omgwtfbyobbq's Avatar
The power band does not usually equate to efficiency at a cruise.
Old 09-29-2007, 02:52 PM   #17
i know from my f150 that it's possible to gear too high. it falls "off the cam" and without retuning (cam, intake, exhaust) for the lower rpm ops the fe gains just weren't there for me.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 09-29-2007, 04:10 PM   #18
How do you know it's a problem with the intake/exhaust profile and not the TCC?
Old 09-29-2007, 05:25 PM   #19
peak torque = max efficiency....
engine is most efficient, when it is at the rpm where its making the most peak power.
Pyrorocketeer is offline   Reply With Quote
Old 09-29-2007, 05:36 PM   #20
I got a few BSFC maps that disagree with that. Not to say that it's impossible for peak torque and minimum BSFC to coincide, just that it generally doesn't happen IME.
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 03:01 PM
VW Jetta fast riser coolbreeze General Fuel Topics 5 07-22-2009 12:25 AM
DIY: Wire Tuck!!! SVOboy Experiments, Modifications and DIY 11 09-21-2006 05:17 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
