12-23-2008, 03:14 PM
Originally Posted by dkjones96
That just HAS to be an exaggeration. I can't (and won't) believe for a second that the engine has to create anywhere near 15-20 more hp if the car is in gear vs neutral.
In fact, if I remember correctly from my data logging on Tracker, calculated load was mostly unaffected(+-1%) by neutral vs drive. However, turning on the a/c yielded a 15% increase in calculated load.
Fuel rate is barely affected by D vs. N at a stop, but it is affected. Injector duty cycle might be ~1.3% in N and ~1.5% in D. That's a pretty significant difference comparing the two, but the amount we're talking about isn't much. It is enough to be worthwhile, IMO...you don't have anything to lose by doing it.
Originally Posted by VetteOwner
maybe theyve changed alot since 97
I believe that they have. I think in addition to adding gears (Many 2008 GM autos are 6 speed, vs. all being 4 speed in 1997), the computer control has been worked on and the programming improved. Most come with some kind of manual control, and I suspect that they have been made more robust to tolerate that combined with 100,000 mile warranties.
I don't know if this is attributable to 5 (or 15) years difference or just the difference in vehicles, but my 2002 GMC's transmission behaves way better than my 1997 Pontiac or 1987 Cadillac did. The Pontiac and Cadillac revved too high (and the Cadillac had a power curve like a diesel, really needing low-RPM high-torque driving), while the GMC shifts low and lets me put some gas pedal into it without jumping to redline at the drop of a hat...but if I drop the hammer, it downshifts right away and takes off.
doesnt engine brake at all (well does but takes a friggin mile to do so)
Most automatics should not engine brake automatically under most conditions. It is more efficient to go to the highest gear and unlock the torque converter when the driver lets off the gas pedal.
An automatic driver who wants engine braking is advised to make use of the different positions for the gear selector, or on late model vehicles, to use the tiptronic/paddle shifters/etc. That's one of the main reasons those things are included in the user interface.
since we like to do our own service work that when a computer buggers up or something fails and throws the SES light were SOL since we dont own a obdII scanner or anything...
You don't have to spend $200 on a ScanGauge to get an OBDII scanner. Harbor Freight sells a basic unit that will pull codes from any car for $40, or you can go to the nearest chain auto parts store like Auto Zone and get your codes pulled for free (make sure you insist on getting the code numbers instead of just the vague description) (illegal in California).
