-- Anyone put a transmission pump to EOC --- - Page 3 - Fuelly Forums
Old 12-24-2008, 04:36 PM   #21
kamesama980's Avatar
What I've always heard is to avoid 'power purge' transmission fluid exchanges like the aamco thing. some fluid in/out exchangers use a single tank with a sort of piston between them so the in/out pressure is similar....those are OK AFAIK
as for the change intervals... they vary between year, model, and mfr as widely as the looks. they can be anywhere from 20k to 100k to "non-serviceable" however that doesn't mean you SHOULD go that long. as for the 'regular' and 'severe duty' conditions, unless you drive 90% highway without towing you most likely qualify for severe duty.
-Russell
Old 06-07-2009, 07:18 AM   #22
Hmmm, I wonder if a regular old power steering pump on the driveshaft would do?
Depends on the transmission/car layout, I guess, but it should flow well enough...I THINK!!
rust collector is offline   Reply With Quote
Old 06-07-2009, 08:11 AM   #23
Revisiting what I mentioned but didn't elaborate on in an earlier post in this thread...here's a pump made for this purpose:
http://www.remcotowing.com/node/6
Tow your vehicle on all four wheels without the need of dollies. No odometer mileage accumulation on vehicles with electronic speedometers. All that from a patented system that a mechanic can install in approximately 6 hours.
Looks like it costs $1000, though, so it wouldn't make sense for EOC. $1000 buys a lot of gas...
Hybrids may pose greater risk for pedestrians! rgathright Automotive News, Articles and Products 6 05-14-2008 07:18 PM
NJ HX Rims $200 UfoTofU For Sale 1 02-23-2007 01:25 AM
2006 Pontiac G6 Silveredwings Car Reviews 5 02-11-2007 06:38 PM
A RAV4 to go with the Prius? krousdb General Discussion (Off-Topic) 31 12-30-2006 05:32 AM
vx 5 wire o2 sensors on eBay!!! budomove For Sale 3 12-19-2006 07:41 AM
