A noob's adventures in old technology - Page 3 - Fuelly Forums
Old 11-28-2009, 04:18 PM   #21
Remember that #1 on a GM is always drivers side, all the way forward. Also consider that your timing may be off now that you've been messing with the distributor. Do you have a timing light?
Old 11-28-2009, 04:20 PM   #22
I will try switching them and see what happens.
Old 11-28-2009, 04:28 PM   #23
I wish you were closer. I'd love to go up there and play with it. I am very well versed in early 80's GM engines. I've owned my 81 Regal for almost 19 years, I grew up helping dad work on our 1980 Pontiac wagon, my 81 AMC Spirit had a Pontiac Iron Duke (151) in it, plus the experience I picked up working on my 74 and 86 Chevy trucks... I know a lot about early 80's GM.
Old 11-28-2009, 06:42 PM   #24
GasSavers_JoeBob's Avatar
If the engine is running reasonably smoothly, I wouldn't think there'd be a problem with the plug wires being crossed up. The lack of power above 45 mph sounds a lot like clogged fuel filter, which in my limited experience causes a car to run fine at idle, or slow speeds, and like a dead dog climbing hills or on the freeway.
Old 11-28-2009, 06:52 PM   #25
Yeah, when I thought in that direction, I very temporarily forgot that it was doing that before, too.
Edit: The fuel filter is $3. Hooray! Where on the car is it?
Old 11-28-2009, 07:10 PM   #26
I can't say for sure on your car...if the fuel pump is in the tank then it is probably under the car somewhere. If it is a mechanical fuel pump it is probably on the inlet to the carb.
Old 11-28-2009, 07:19 PM   #27
Arrow
HC's car has a mechanical fuel pump mounted on the side of the engine block. The fuel filter is located in the carb. Look at where the fuel line goes into the carb. Disconnect the aluminum fuel supply line from the carb. You will notice that the fuel line is screwed into a large brass bushing on the carb. Remove this bushing. The fuel filter is behind it. Make sure the new filter is put in facing the proper direction. The check valve will be facing out, and the brass endcap on the filter will be towards the back. If put in backwards the engine probably would not run at all.
Old 11-29-2009, 12:46 PM   #28
Nope. Not gonna happen. I don't think that nut is coming loose unless I take the carburetor off, cut the fuel line, and replace it. It's acting like the nut on my truck's fuel filter did.
Old 11-29-2009, 01:24 PM   #29
Sorry HC, but this thread is almost as funny as my granddaughters fascination with the crank up windows in my car . Drove 5 miles down the road with her winding the window up-down-up-down-up-down.
regards
Gary
Old 11-29-2009, 01:34 PM   #30
Soak it with PBBlaster. Best stuff I've seen yet for stuck nuts. You DO have a tubing wrench, don't you? If not, get one. They're not expensive. Nut's already rounded off? Time for Vise-Grips.
WTB - Steel Rims - 4 x 114.3 Bolt Pattern - 15 x 6JJ LastBoyScout Wanted to Buy 0 09-11-2008 10:08 PM
WTB - Civic HX wheels GasSavers_slats For Sale 0 03-16-2008 12:08 AM
Unmodified '89 CRX HF in MD $900 Danronian For Sale 4 11-07-2007 08:52 AM
aerodynamics episode kitcar Aerodynamics 2 06-15-2007 07:04 PM
A Japanese Study on Vehicle Idling SVOboy General Fuel Topics 0 05-12-2007 01:25 PM
