95 VX.. will not start. Died in reverse. - Page 2 - Fuelly Forums
Old 05-07-2012, 06:48 PM   #11
add|ct's Avatar
Re: 95 VX.. will not start. Died in reverse.
Yeah, the videos I posted should help you diagnose which component in the ignition is failed.
You 'may' worst case have issues with wiring or distributor itself; however it may only be an igniter or ignition coil(instead of an entire distributor). Do the tests in the videos I linked, be sure you ARE NOT the path to ground. Verify the engine grounds are in tact for kicks.
If you pull a spark plug after cranking, do you see wetness and gasoline smell?
...and for kicks, battery voltage/amp readings are what?
'92 Civic VX, Canadian model
Old 05-08-2012, 04:54 AM   #12
Here's another thought . . . Roll it down a hill and bump start it! But make sure you can tow it back up the hill with some other vehicle. Just an idea in case the starting circuit has a problem.
Old 05-08-2012, 11:41 AM   #13
mrmad's Avatar
Have you checked the coil? You can do this with a multimeter.
Old 05-31-2012, 08:41 AM   #14
Member
The coil on my VX died. Started the car and then shut it off after a few seconds. Tried to start again a few minutes later and it was dead. No spark. The coil was the problem. I replaced the module first though. Since I've had a few modules drop dead on prior Hondas I had to choose between replacing the module or the coil. Found a cheap one on ebay and it's been fine now for a couple years.
N2UAD is offline   Reply With Quote
Old 05-31-2012, 12:19 PM   #15
add|ct's Avatar
By module, do you mean igniter? The part the coil sits on top of?
Old 08-10-2012, 02:37 PM   #16
Did you ever figure this out? Having a no spark issue myself
1carnut is offline   Reply With Quote
Old 08-11-2012, 09:12 AM   #17
I found my issue. I followed the testing here... http://www.team-integra.net/forum/bl...eshooting.html
and it turned out to be the ICM in my case. I could not get the primary coil test to give me the correct result so I had replaced that first but it was not the issue.
Brakes 1993CivicVX General Fuel Topics 3 10-05-2007 03:27 AM
New Dodge sub-compact from China. Fuzzy5150 General Fuel Topics 45 07-16-2007 04:39 AM
Wheel covers Telco Aerodynamics 6 05-27-2007 05:25 AM
